Hi
I would ask about executing file of ADS simulation. I mean if I design patch antenna at schematic and layout and do simulation. but I want to run the file in command prompt Ms-dos. how can I do it?
You can simulate a netlist from the command line, see online help "Home > Simulation > Simulation-Analog RF > Using Circuit Simulators", there is a paragraph "Running a Simulation from the Command Line"
I understand that you want to run a Momentum EM simulation from command line? Why?
