They can be found in fek0 installation directory under examples/simple. In the doc dir, u have the getting started guide, user guide and example guide. Lots of examples in there with corresponding codes in the simple dir.
Hope this helps.
Rgdz,
Element7k
coniglioe said:
hi
where i can find examples on microstrip antenna on feko
Do you know where I can find tutorials about FEKO.
I'm using FEKO suite 5.1, and i'm trying to design a circular horn escited with TE11 mode. Do you have more info about how to define the AW card in EDITFEKO ? And how I should place the port ?
You can find a very good tutorial file at the link below. This is part of the official training materials EMSS uses in their courses. Of course, you can find more detailed information about using FEKO in the user manual that comes with installation. I think you already find the answers to your other questions. Good luck with FEKO.
go to c drive in your computer.
then go to program files.
find "feko" folder.
open 5.5 or 6.0 folder
you will find various examples there.
if they do not load. copy one of them on desktop and then load it to feko and try again.
