Even Page Address Boundary
electronicsman
Full Member level 5
Full Member level 5
This is the statement i have seen in the dspic33ev family reference manual. "The program memory must be erased at an “even” page address boundary."
My calculations are 1 page is 8 rows, one row is 64 instructions hence 1 page = 8 * 64 = 512 instructions. As per the diagram the user flash memory starts at 0x000200. Hence the first page address falls at 0x000200 and the next page address falls at 0x000200 + 0x200 (512d) = 0x000400 and so on. Am I correct in this? Then what is this "even" page address boundary? Really confused. Please help.
I have written the following code to erase a page of flash memory. I have not yet started testing but please correct me if i made any mistake it will help me a lot. The compiler is XC16.
#include<xc.h>
 * Program to erase a page of flash memory
 * family:dspic33ev256gm106
_FOSCSEL(FNOSC_FRC & IESO_OFF);
_FOSC(FCKSM_CSECMD & OSCIOFNC_OFF & POSCMD_XT);
_FWDT(FWDTEN_OFF)
_FICD(ICS_PGD2)
#define MEMORY_PAGE_ERASE_OPERATION     (3u)
#define WREN                            (1 << 14)
#define NVMOP                           (MEMORY_PAGE_ERASE_OPERATION)
#define FLASH_PAGE_ERASE_CODE           (WREN | NVMOP)
#define SET                             (1u)
#define PM_ROW	__attribute__((space(prog), aligned(2)))
const PM_ROW eoldata_in_flash[10];
unsigned int nvmAdru;
unsigned int nvmAdr;
unsigned int nvmAdrPageAligned;
int main(int argc , char *argv[])
 PLLFBD=38;              // M=40
 CLKDIVbits.PLLPOST=1;   // N2=4
 CLKDIVbits.PLLPRE=0;    // N1=2
// Initiate Clock Switch to Primary Oscillator with PLL (NOSC=0b011)
__builtin_write_OSCCONH(0x03);
__builtin_write_OSCCONL(OSCCON | 0x01);
// Wait for Clock switch to occur
while (OSCCONbits.COSC!= 0b011);
// Wait for PLL to locke
while (OSCCONbits.LOCK!= 1);
    /*step1  ---> set the NVMOP<3:0> to erase the page of flash program memory */
    NVMCON = FLASH_PAGE_ERASE_CODE;
    /*step2: write the starting address of the page to be erased into NVMADRU and NVMADR registers */
    nvmAdru=__builtin_tblpage(&eoldata_in_flash[0]);
	nvmAdr=__builtin_tbloffset(&eoldata_in_flash[0]);
	nvmAdrPageAligned=nvmAdr & 0xFC00;			/* Get the Flash Page Aligned address */
    NVMADRU = nvmAdru;
    NVMADR = nvmAdrPageAligned;
    /*step3: with interrupts disabled write the key sequence */
    __builtin_write_NVM();
    /* set the WR bit it will start erase operation */
    NVMCONbits.WR = SET;
    while(1);
    return 0;
