Evaluating resistance knowing only the colors of resistor?
gupta
Junior Member level 1
karachi, pakistan
resistance evaluation
i've a resistor with off-white coloured body and only one black colour band on it. how i can determine its resistance ?
Re: resistance evaluation
One black ring usually describes 0Ω resistor ..
Yes and they are used as jumpers in circuits. An ohmmeter also would give you a value for any resistor if it is not bad.
it is the jumper.if u want to find its resistance use some low resistance measurement device
Such type of resistor is used as a jumper but be carefull abt the current rating. Every resistor has a certain range of current that it can handle....
You should take the resistor and isolate of the circuit and you use a Multimeter, you choice the Ohmeter funtion an you probe the resistor, the value that appear in the display is the value of the resistor.
