EUSART Test code for PIC18F45K22 in C language
VoltVolt
Junior Member level 1
Anyone can share his/her UART sample code for PIC18F45K22 (in C language)?
Just want to test whether the hyper terminal and PIC working?
I'm using Cytron UC00B USB to UART converter...
Thanks... :)
#include<stdio.h>
#include<p18f46k22.h>
#include "usart.h"
//#define USE_OR_MASKS
unsigned char Rxdata[8];
unsigned char Txdata[] = "test";
void delay(unsigned int i)
	for(;i>1;i--);
void main(void)
    unsigned char config=0,spbrg=0,baudconfig=0,i=0,j='a';
	OSCCONbits.IRCF0 =1;
	OSCCONbits.IRCF1 = 1;
	OSCCONbits.IRCF2 = 1;
	OSCTUNEbits.PLLEN = 1;
    ANSELA = 0x00;
    ANSELB = 0x00;
    ANSELC = 0x00;
    ANSELD = 0x00;
    ANSELE = 0x00;
	TRISA=0x00;
	TRISB=0X0000;	//output
    TRISC=0Xffff;	//output
    TRISD=0X00;	//output
    TRISE=0X00;	//output
    Close1USART();  //turn off usart if was previously on
//-----configure USART -----
    config = USART_TX_INT_OFF | USART_RX_INT_OFF | USART_ASYNCH_MODE | USART_EIGHT_BIT | USART_SINGLE_RX | USART_BRGH_LOW;
//-----SPBRG needs to be changed depending upon oscillator frequency-------
    spbrg = 51;                    //At 8Mhz of oscillator frequency & baud rate of 2400.
    Open1USART(config, spbrg);        //API configures USART for desired parameters
    baudconfig =  BAUD_8_BIT_RATE | BAUD_AUTO_OFF;
    baud1USART (baudconfig);
//------USART Transmission ----
    while(Busy1USART());             //Check if Usart is busy or not
    puts1USART((char *)Txdata);                //transmit the string
    Close1USART();
    while(1);                        //end of program
Do you mean this?
Where to find usart.h code?
hello,
if this code can help you, even in C18..
tested in real world ! not simulator.
If you want a reliable RS232 link, you MUST use a buffer and UART interrupt treatment..as in this example
and maybe survey the ErrComm counter ...
//18 sept 2013
//03/07/2012
// Pickit3
// TESTE OK  en lecture
// attention: use radix decimal !!
// C18 MPLAB
// directory : _C18\MesProjets_C18\_18F46K22
// Projet :_C18\MesProjets_C18\_18F46K22\18F46K22_test_RS232.mcp
// Source : 18F26K22_test_RS232.c
========== HARDWARE ====================
27 pf  Q=10Mhz 27pF
Interface DS275 pour liaison UART TTL <-> RS232
PIC 18F26K22  28 pins DIP
PortB
 RB0   21   input
 RB1   22
 RB2   23
 RB3   24
 RB4   25
 RB5   26
 RB6   27  ICSP_Clck   Bleu fonce    Pin5 Pickit2
 RB7   28  ICSP_Data   Bleu clair    Pin4 Pickit2
PORTA
 RA0   2  Analog Input for AC line meaurement
 RA1   3
 RA2   4
 RA3   5
 RA4   6  Output .. Led .. 390 ohms +5V
 RA5   7  Output
 RA6   8  ----- Quartz 10Mhz   C=22pF -- Gnd
 RA7   9  ------ Quartz ---    C=22pF -- Gnd
PORTC
 RC0   11
 RC1   12
 RC2   13
 RC3   14
 RC4   15  SCL I2C  LCD4x20
 RC5   16  SDA I2C  LCD4x20                                      depend si DTE ou DCE
 RC6   17  TX  UART1 --Blc---  3 de DS275 7 -- blanc ----> 2HE10 -nappe --DB9M DB9F cable RS232 PC
 RC7   18  RX  UART1 --rouge-  1 de DS275 5 ---bleu Fce -< 3HE10 -nappe --DB9M DB9F cable RS232 PC
           Gnd ------------------------------------------>5 HE10 -nappe ---DB9M DB9F cable RS232 PC
      1   --- jaune -- VPP/MCLR ---  pin1 Pickit2
      8  ---- blanc ------Gnd-----  pin3 Pickit2
 VSS  8   ----  GND Power
 VSS  19  ----  GND Power
 VDD  20  ----  +5V Power
#include "p18f26k22.h"
#define p18f26k22
#define Versus "Versus 130917 C18   "
#include "stdio.h"
#include <stdlib.h>
#include <delays.h>
#include <string.h>
#include <usart.h>   // pour fonctions UART HARDWARE
#include <adc.h>
#include <ctype.h>
#include <portb.h>
#include <timers.h>
#include <math.h>
// configuration bits set in code !
// voir Help
//  Topics
//        Pic18
//            config bits settings
//                    choisir PIC18F26K22
#ifdef OSCILLATEUR_INTERNE
#pragma config FOSC = INTIO67, FCMEN = OFF, PLLCFG=OFF            // CONFIG1H
#else
#pragma config FOSC = HSMP, PLLCFG=OFF, PRICLKEN=ON ,FCMEN=OFF      // quartz 10Mhz
#endif
#pragma config IESO=OFF,PWRTEN=OFF,BOREN=OFF,WDTEN=OFF,CCP2MX=PORTC1
#pragma config PBADEN=OFF,T3CMX=PORTC0,P2BMX=PORTC0,CCP3MX=PORTB5
#pragma config MCLRE=EXTMCLR,STVREN=OFF,LVP=ON,XINST=OFF,DEBUG=OFF
#pragma config CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF                    // CONFIG5L
#pragma config CPB = OFF, CPD = OFF                                          // CONFIG5H
#pragma config WRT0 = OFF, WRT1 = OFF, WRT2 = OFF, WRT3 = OFF                // CONFIG6L
#pragma config WRTB = OFF, WRTC = OFF, WRTD = OFF                            // CONFIG6H
#pragma config EBTR0 = OFF, EBTR1 = OFF, EBTR2 = OFF, EBTR3 = OFF            // CONFIG7L
#pragma config EBTRB = OFF                                                   // CONFIG7H
// config vue sur Pickit3 : 2200 3C18 9900 0084 C00F E00F 400F
#ifndef Byte
#define Byte unsigned char
#endif
// Using Q=10Mhz  Clock
#define CLOCK_FREQ 10000000L
#define FOSC 10000000
#define DureeCycle 10 // * 1 diziemes de secondes => 1,0sec
// Attention use Radix decimal in MPASM options
#define CLS 12
#define BS 8
#define TAB 9
#define CR 13
#define LF 10
#define Bell 7
#define ON 0	// logique inverse avec led tiree au +5V
#define OFF 1
#define Led_Rouge    PORTAbits.RA4
#define Allume 0
#define Eteint 1
#define MAX_LEN 80
unsigned int  i,j,k;
unsigned int dummy;
unsigned int j1;
unsigned int M;
unsigned int BRG_REG;
volatile int i1;
volatile char  c1;
volatile int count;
volatile unsigned int ErrComm;
long L;
char Texte[]="18F26K22 test RS232 C18\r\n 03/07/2012 rev a\n\r19200bds Quartz 10Mhz \r\n\0";
char *txt;
char buffer[MAX_LEN]="00000000000000000000000";	// buffer de reception
char received;
//--------- RS232 UART HARDWARE --------------
void Init_UART1(void);
int PutStr_RS(char *s);
void Put_RS(char * untel);
void CRLF();
void Tempo(long val);
void Octet2Hex(unsigned char number);
void Decompile_byte(Byte un);
void InterruptHandlerHigh (void);
void Decompile_byte(Byte un) {
Byte masque;
  masque = 0x80;
  while (masque > 0u )
  if (un & masque)
      Put_RS(49u);  //  '1'
    else
      Put_RS(48u);  //  '0'
    masque =masque >>1;
char high,low;
  // high nibble
  high = ((number & 0xF0) >> 4) + 48; // + '0'
  if (high > '9')
    high =high + 7;
 // low nibble
  low = (number & 0x0F) + 48;          // +'0' low nibble
  if (low > '9')                       // '9'= 57u
    low += 7;                         // > '9'
  Put_RS(high);
  Put_RS(low);
  Put_RS('h');
//gestionnaire d'interruption
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh (void)
  _asm
    goto InterruptHandlerHigh //jump to interrupt routine
  _endasm
// High priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerHigh
void InterruptHandlerHigh ()
  static char i ; // doit être statique pour conserver sa valeur entre les IT
  char C ;
//======== SERIAL======================
if(PIR1bits.RC1IF) // si une interruption UART1 arrive
  c1 =Read1USART(); // le lire => RAZ  RCIF
  if(RCSTA1bits.FERR==1 )
     RCSTA1bits.SPEN = 0 ;
     RCSTA1bits.SPEN= 1 ;
    c1 =Read1USART();
    ErrComm++;
   if (RCSTA1bits.OERR==1)    // voir parag 16.1.26 p273
       RCSTA1bits.CREN = 0 ;
       RCSTA1bits.CREN = 1 ;
       ErrComm++;
// if you want to echoed ,uncomment the 2 following lines
//    while(Busy1USART()); // par sécurité
//    if (PORTBbits.RB1==0) Write1USART(C); // echo
      if(C != CR && i<MAX_LEN)
        buffer[i++]=C ; // stockage
        }else
         buffer[i]='\0'; // fin de chaîne si CR
         i=0;
         received =1;
       } //if PIRbits.RCIF
} // fin de routine interrupts
// USART_BRGH_HIGH,32
// init 38400Bd a 20Mhz
// init 19200Bd a 10Mhz avec IT en rx
// voir para 18.5 spec sheet DS41159B page 186
Open1USART( USART_TX_INT_OFF &
USART_RX_INT_ON &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH,32
INTCONbits.PEIE = 0 ; // autorisation des IT des périphériques
INTCONbits.GIE = 0 ; // autorisation globale des IT
	int n;
	for (n = 0; *s; n++, s++)
       	Put_RS(*s);
	return n;
   	Write1USART(untel);
void CRLF()
  Put_RS(CR);  Put_RS(LF);
while(val>0){val--;}
void main()
char a;
unsigned char d;
//OSCCON =0b01100000;
ANSELA=0;
TRISA = 0b00001111 ;
TRISAbits.TRISA4 = 0;   // led rouge
LATA = 0x00;
ANSELC=0;
TRISCbits.TRISC6 = 0;
TRISCbits.TRISC7 = 1;
Led_Rouge=Allume;
Init_UART1();
Put_RS(CLS);   // clear  Vbray terminal Screen
Tempo(150000L);
Put_RS('*');
CRLF();
Put_RS('#');
CRLF();
// init pour interruptions ----
  INTCONbits.GIE = 1;    // active global interrupt
  INTCONbits.GIEL=1;
  RCSTA1bits.CREN= 1 ;
  PIE1bits.RC1IE = 1;
  INTCONbits.PEIE = 1;   // autorisation des IT des périphériques
ErrComm=0;
buffer[0]=0;
received=0;
txt=&Texte[0];
k=PutStr_RS(txt);
CRLF();
Tempo(20000);
// write to the USART
k=fprintf(_H_USART,"Init UART 19200bds Q=10Mhz\r\n");
k=fprintf(_H_USART,"hello\r\n");
k=fprintf(_H_USART,"Type some chars and CR to send them: ");
buffer[0]=0;
while(1)
 if (received==1) // test if reception occured
  j=0;
  Led_Rouge=Allume;
 k= fprintf(_H_USART,"\r\nKeyboard entry : ");
  while (buffer[j]!=0)
    a=buffer[j];
    Put_RS(a);
    j++;
  received=0;
  buffer[0]=0;
Tempo(25000L);
Led_Rouge=!Led_Rouge;
/* results on Vbray terminal
 03/07/2012 rev a
hello
Keyboard entry :
Keyboard entry : hello chaps !
Keyboard entry : How are you today ?
Even I am having the same problem I am using PIC18f4550 and programming it through C18 Compiler
I have got to know about the uart.h file but still I am confused that how to set
OpenUSART(config, spbrg);
Can any one illustrates me how to set the external crystal oscillator frequency like I am using 16Mhz Crystal oscillator
SO how to set this in the code
Even I've gone through the ""Configuration bit settings"" there are twelve mode for oscillator selection
like HS , EC mode
I have done that LED Blinking through the same iDE by selecting ""HS Oscillator"" in the configuration bits Setting
Please help me out in writing USART code
