I am studing LAN9252 for my next project. I need connect a PIC MCU with an industrial PLC. The PIC needs send to a PLC 80 bytes each 20ms.
In LAN9252 datasheet I found the information about FIFO: the buffers for data send and received. So, I only can comunicate 32 bytes (32 input + 32 output) each time?
You need to consider what's the structure of PLC data and how should it be represented in EtherCAT data space. It's basically possible to multiplex 80 Byte into a 32 Byte window, but a higher update rate is required in return.
Hm... ok. But, the LAN9252 only can send 32 bytes? in other words, in XML file (file for PLC configure device in network) I can define more bytes than 32?
Ok, thank you. Another question: there is other IC Slave Controller (like the LAN9252) but with larger PDO size? I searched in some manufacturers but nothing... Thank you
