Based on my caluculation, the esr of electrolytic capacitor I used is 0.15*1/(2*pi*120*220e-6)=0.9043 ohm, which is very large. Do I calculate it right? I am still wondering what kind of capacitor should be used as output filter in DC-DC convert?
Assuming the 220uF cap has ESR = 1Ω, then the impedance of the 10uF poly cap will be lower than that of the 220uF above 16KHz. At lower frequencies, the impedance is set by the 220Uf cap.if I parallel a 220uF aluminum with 10uF polypropylene, how do I calculate ESR? Just parallel two ESR?
If this is control loop analysis, then the ESR at the switching frequency probably isn't very relevant. Rather, you should be interested in ESR within the loop bandwidth of the controller.I need to use esr to calculate feedback loop parameters, how would I do with alum cap parallel with poly cap?
