void uart_swap(uart_t* uart, int tx_pin)
if(uart == NULL) {
return;
switch(uart->uart_nr) {
case UART0:
if(((uart->tx_pin == 1 || uart->tx_pin == 2) && uart->tx_enabled) || (uart->rx_pin == 3 && uart->rx_enabled)) {
if(uart->tx_enabled) { //TX
pinMode(uart->tx_pin, INPUT);
uart->tx_pin = 15;
if(uart->rx_enabled) { //RX
pinMode(uart->rx_pin, INPUT);
uart->rx_pin = 13;
pinMode(uart->tx_pin, FUNCTION_4); //TX
pinMode(uart->rx_pin, FUNCTION_4); //RX
IOSWAP |= (1 << IOSWAPU0);
} else {
uart->tx_pin = (tx_pin == 2)?2:1;
uart->rx_pin = 3;
pinMode(uart->tx_pin, (tx_pin == 2)?FUNCTION_4:SPECIAL); //TX
pinMode(3, SPECIAL); //RX
IOSWAP &= ~(1 << IOSWAPU0);
break;
case UART1:
// Currently no swap possible! See GPIO pins used by UART
break;
default:
break;
