Error with PIC10f and High Tech C
M3GAPL3X
Junior Member level 3
wdtcon htc
Hi Guys,
I am getting the following errors for some reason. Basically I am using a counter to keep track of how long a button is pressed. The WDT wakes up every 18 ms.
#include <htc.h>
#define BUTTON_INPUT GP0
//Sleep command
void Sleep(void)
#asm
	sleep
#endasm
//main function
void main()
	while(1) //do forever
		CLRWDT(); //clear the watchdog timer
		CheckButton(); //check button
		WDTCON = 1; //enable the watchdog timer
		Sleep(); //go to sleep for 18 ms
		WDTCON = 0; //disable the watchdog timer
		CheckButton(); //check button again
//Function: CheckButton
//Description: Check the state of RC2
//if active low, increment COUNTER. Check COUNTER to see if it is over 3 seconds. If so, provide power
//to main computer. If active high, reset COUNTER to 0
void CheckButton(void)
	unsigned int COUNTER = 0;
	if (BUTTON_INPUT == 0) //if an active low, increment the COUNTER
			COUNTER++;
			if (COUNTER >= 10000) //3
					//SEND POWER TO HOST, IN TESTING, LIGHT AN LED
		else //else - reset the COUNTER value back to 0 because button is not pressed
				COUNTER = 0;
I get the following error:
19.1 undefined identifier "WDTCON"
millwood
Advanced Member level 3
wdtcon = 1 htc
that means WDTCON is undefined. you need to read the datasheet and the headerfile to see what is appropriate for the chip you are programming for.
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
pic10f c program hi-tech
As far as I can remember, the watchdog timer cannot be enabled or disabled in software. The watchdog is controlled by a bit in the configuration fuses which have to be set when the device is programmed.
Brian.
M3GAPL3X
hi-tech c sleep command
Thanks guys. I believe Brian is right. The PIC10f series has no software control of the WDT!!
