Error when using "verilog +gui" command in Cadence ICFB
sar_1232000
Newbie level 3
Newbie level 3
Iam trying to simulate verilog files using cadence icfb. I could import the files. But for simulation, I need to use the command "verilog +gui <filename>". It gives the error:
verilog:command not found
icfb doesn't have verilog by default? How can I check if verilog is installed? This is the first time Iam using icfb and have no idea about it.
Can anyone please help me out?
Thanks,
Aarthi.
icfb cadence
You must install a verilog tool like verilog-xl or ncverilog separately. They comes with IUS package (prev. LDV package).
icfb command not found
check if you have the path of the binary (/bin) "verilog" defined in your source file
icfb &
azerm is right.
To compile Verilog codes, you have to install the IUS package and the command is 'ncverilog' and 'ncsim'.
cadence icfb verilog
right. ncverilog is the verilog compiler. verilog command is for verilog-XL, different from nclaunch.
