kasey
Newbie level 3
design contains no nets
Hi all,
I'm using Libero IDE, and after synthesis, I did the Place & Route and The Execute Script command succeeded, but when I clicked on Compile, there's 1 error stating "Error: CMP010: A design must contain at least one net". If anyone have encountered this same error or know how to fix it, please provide help. I also looked up the online help for compile errors and the solution was "Ensure that there is at least once I/O output and one internal net. Correct problem in the design source and re-import the netlist." Thank you in advance.
Hi all,
