pads11
Pads2005 CAM error - system fonts not supported for rs274d gerber format
I have a pcb file in pads2005 that was imported from 2007 pads via ascii file.
Other than changing some fonts to arial, the import went fine.
Now when trying to run gerbers in pads 2005 I get error saying "System fonts are not supported for RS274D Gerber format. Consequently, all text strings using system fonts were skipped"
Once the cam has run to the end, all the text is missing from cam files. So all reference designators are missing, silkscreen labelling, etc. I've tried changing all the fonts to some other font, like verdana for example but the same problem persists.
Has anyone seen this before and what can be done to fix it ?
