[ARM] Error[Pe159]: declaration is incompatible with previous ........
Trần Tài
Hà Nội
I get this Error and I don't understand when I look at my code, why is it incompatible???? Please help me, tks so much :cry:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
#include "stm8s.h"
// SO DO KET NOI DEN LCD 16X2 CHE DO 4 BIT
#define LCD_RS  PD_ODR_ODR5
#define LCD_EN  PD_ODR_ODR6
#define LCD_RW  0
#define LCD_D4  PC_ODR_ODR4
#define LCD_D5  PC_ODR_ODR5
#define LCD_D6  PC_ODR_ODR6
#define LCD_D7  PC_ODR_ODR7
#define line_1          0x80
#define line_2          0xC0
#define clr_scr         0x01
#define DQ PB_ODR_ODR5
#define line_1 0x80
#define line_2 0xC0
unsigned char temp1;
typedef unsigned char uchar;
//********************delay************************
void delay(unsigned long int t);
//********************LCD Funtion***********************
//********************tao xung*******************************************
void enable();
//**********convert data-->send to Pin of microcontrol****************************
void set_data_lsb(unsigned char data);  //ham gui byte data thap
void set_data_msb(unsigned char data);  //ham gui byte data cao
//************************HAM GUI LENH******************************************
void put_cmd(unsigned char cmd);
//**************************ham gui data*************************************
void lcd_putchar(unsigned char data);
void lcd_putsf(uchar *s);
//****************HTLCD************************************************
//****************************ham khoi tao lcd*************************
void lcd_init();
  void main(void) {
    CLK_DeInit();
    CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);      //f_Master = HSI/1 = 16MHz
    CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV16);            //f_CPU = f_Master/1 = 16MHz
    while(CLK_GetFlagStatus(CLK_FLAG_HSIRDY)!=SET);     //wait until HSI ready
  GPIO_DeInit(GPIOC);
  GPIO_Init(GPIOC, GPIO_PIN_ALL, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_DeInit(GPIOD);
  GPIO_Init(GPIOD, GPIO_PIN_ALL, GPIO_MODE_OUT_PP_LOW_FAST);
      lcd_init();
      put_cmd(clr_scr);
      delay(100);
               put_cmd(line_1);
        lcd_putsf("Tran Quoc Tai");
        put_cmd(line_2);
        lcd_putsf("  Xin chao ban  ");
        put_cmd(0x10);
        delay(1000000);
  while(1)
 lcd_init();
      put_cmd(clr_scr);
      delay(100);
               put_cmd(line_1);
        put_cmd(line_2);
        put_cmd(0x10);
        delay(1000000);
void main(void){
  CLK_DeInit();
  CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);// fMaster = HSI/1 = 16MHz
  CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV16);//fCPU = HSI/1 = 16MHz
  while(CLK_GetFlagStatus(CLK_FLAG_HSIRDY)!=SET);// cho den khi HSI bat dau
    GPIO_DeInit(GPIOC);
  GPIO_Init(GPIOC,GPIO_PIN_ALL,GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_DeInit(GPIOD);
  GPIO_Init(GPIOD,GPIO_PIN_ALL,GPIO_MODE_OUT_PP_LOW_FAST);
  lcd_init();
  put_cmd(clr_scr);
  lcd_init();// khoi tao
  delay_b20(200);
  lcd_putsf("Do nhiet do: ");// gui chuoi
  put_cmd(0x01);// clear LCD
  lcd_gotoxy(0,1);
  while(1){
    lcd_gotoxy(0,0);
    ReadTemperature();
    TempShow(temp1);
    delay_b20(500);
  // tre ds18b20
  int delay_b20(unsigned int ti){
   while(ti--);
//khoi tao ds18b20
  void Init_ds18b20(void){
    DQ = 1;
    delay_b20(5);
    DQ = 0;
    delay_b20(10);
    DQ = 1;
    delay_b20(20);
 unsigned char ReadOneChar(void){
   unsigned char i;
   unsigned char dat = 0;
   for(i=8;i>0;i++){
     DQ = 0;
     dat>>=1;
     DQ = 1;
     if(DQ)
       dat |= 0x80;
     delay_b20(10);
   return(dat);
  void WriteOneChar(unsigned char dat){
    unsigned char i;
    for(i=8;i>0;i++){
      DQ = 0;
      DQ = dat&0x01;
      delay_b20(5);
      DQ = 1;
      dat>>=1;
  void ReadTemperature(void){
    unsigned char a = 0;
    unsigned char b = 0;
    //EA = 0;// cam ngat tranh qua trinh doc nhiet do bi anh huong
    Init_ds18b20();
    WriteOneChar(0xCC);// bo qua ROM
    WriteOneChar(0x44);
    delay_b20(10);
    Init_ds18b20();
    WriteOneChar(0xCC);
    WriteOneChar(0xBE);// doc nhiet do
    delay_b20(10);
    a = ReadOneChar();
    b = ReadOneChar();
    temp1 = ((b*256+a)>>4);// doc nhiet do luu vao bien temp
    //EA = 1;// doc xong thi cho phep ngat
  void TempShow(unsigned char z){// doc nhiet do
    lcd_putsf("Nhiet do: ");
    lcd_putchar((z/100)+48);// hang tram
    lcd_putchar((z%100/10)+48);// hang chuc
    lcd_putchar((z%10)+48);// hang don vi
    lcd_putsf("oC");
  unsigned long int i=0;
  for(i=0;i<t;i++);
void enable()
GPIO_WriteHigh(GPIOD, GPIO_PIN_6);  delay(10);
GPIO_WriteLow(GPIOD, GPIO_PIN_6);  delay(20);
void set_data_lsb(unsigned char data)  //ham gui byte data thap
unsigned char temp;
temp = (data<<4) & 0xF0;
GPIO_Write(GPIOC,temp);
void set_data_msb(unsigned char data)  //ham gui byte data cao
unsigned char temp;
temp = (data) & 0xF0;
  set_data_msb(cmd);
  GPIO_WriteLow(GPIOD, GPIO_PIN_5);
  enable();
  set_data_lsb(cmd);
  enable();
  set_data_msb(data);
  GPIO_WriteHigh(GPIOD, GPIO_PIN_5);
  enable();
  set_data_lsb(data);
  enable();
  while(*s)
    lcd_putchar(*s);
    s++;
void lcd_init()
  delay(100);
  set_data_lsb(0x03);
  enable();
  enable();
  enable();
  set_data_lsb(0x02);
  enable();
    put_cmd ( 0x28 );    //cd 4bit,2dong,5x7
    put_cmd ( 0x0C);     //bat hien thi,tat con tro
    put_cmd ( 0x06 );    //* entry mode set, increment & scroll left
    put_cmd ( 0x01 );    //* clear display
void lcd_gotoxy(unsigned char x, unsigned char y){// toa do
  unsigned char address;
  if(!y)
    address = line_1+x;
  else address = line_2+x;// xac dinh vi tri con tro
  delay_b20(100);
  put_cmd(address);
  delay_b20(200);
Im so sorry, I forget to post the pic
It may be because you did not give the compiler a prototype of "ReadTemperature()", forcing it to use an assumed type.
There are prototypes for almost everything else, so give that a try.
tks so much but I see the algorith is true, :-( I can't do anything
Trần Tài;1432799 said:
I can't do anything
The remark gave by wade_hassler makes all sense.
You are using a function on line #144 that was implemented after, on line #159.
As mentioned before, you can try inserting the code bellow at line #2 of your code above.
void ReadTemperature(void) ;
