error in vhdl while compiling in vhdl
goodpranoy
Junior Member level 3
Error: H:/ollade_latest/datapath_latest_collage.vhd(53): Cannot assign to object "d1" of mode IN.
** Error: H:/ollade_latest/datapath_latest_collage.vhd(54): Cannot assign to object "d2" of mode IN.
** Error: H:/ollade_latest/datapath_latest_collage.vhd(58): VHDL Compiler exiting
i am getting these errors when running the following programs. pls help.
library ieee;
    use ieee.std_logic_1164.all;
    --use ieee.std_logic_unsigned.all;
    entity datapath_latest is
        port(
            D1:in std_logic_vector(7 downto 0);
            D2:in std_logic_vector(7 downto 0);
            Dout:out std_logic_vector(7 downto 0);
            control:in std_logic_vector(2 downto 0);
            load:in std_logic_vector(2 downto 0)
        end datapath_latest;
        architecture behav of datapath_latest is
        signal reg_a_data_in : std_logic_vector(7 downto 0 );
        signal reg_b_data_in : std_logic_vector(7 downto 0 );
        signal reg_a_data_out : std_logic_vector(7 downto 0 );
        signal reg_b_data_out : std_logic_vector(7 downto 0 );
        signal a_move : std_logic_vector(7 downto 0 );
        signal b_move : std_logic_vector(7 downto 0 );
        signal d1_signal : std_logic_vector(7 downto 0 );
        signal d2_signal : std_logic_vector(7 downto 0 );
        signal sel_signal : std_logic;
component reg_new
        port( control:in std_logic_vector(2 downto 0);
             data_in:in std_logic_vector(7 downto 0);
            data_out:out std_logic_vector(7 downto 0));
        end component;
component alu_ent
        port(
            x,y:in std_logic_vector(7 downto 0);
            a:in std_logic_vector(2 downto 0);
            reg_a_mov,reg_b_mov:out std_logic_vector(7 downto 0 );
            sel:in std_logic;
            z:out std_logic_vector(7 downto 0)
        end component;
        component MUX
            port(
            d0:in std_logic_vector(7 downto 0);
            d1:in std_logic_vector(7 downto 0);
            s:in std_logic;
            y:out std_logic_vector(7 downto 0)
        end component;
    begin
    mux_a : MUX
    port map(
    d0=>a_move,
    d1=>D1,
    s=>sel_signal,
    y=>reg_a_data_in
    mux_b : MUX
    port map(
    d0=>b_move,
    d1=>D2,
    s=>sel_signal,
    y=>reg_b_data_in
    register_a : reg_new
 port map (
            data_in=>reg_a_data_in,
            control=>load,
            data_out => reg_a_data_out
  register_b : reg_new
 port map (
           data_in=>reg_b_data_in,
           control=>load,
           data_out => reg_b_data_out
  alu:alu_ent
  port map(x=>reg_a_data_out,
           y=>reg_b_data_out,
           z=>Dout,
           reg_a_mov=>a_mov,
           reg_b_mov=>b_mov,
           a=>control,
           sel=>sel_signal
    end behav;
--mux
library ieee;
    entity MUX is
        port(d0,d1:in std_logic_vector(7 downto 0);
            s:in std_logic;
        end MUX;
        architecture MUX_arch of MUX is
            begin
          process(d0,d1,s)
          begin
                case s is
                     when '0'=>
                      y<=d0;
                     when '1'=>
                     y<=d1;
                     when others=>
                      y<="ZZZZZZZZ";
                     end case;
     end process;
         end MUX_arch;
--alu
library ieee;
    entity alu_ent is
        port(
            sel:in std_logic;
        end alu_ent;
        architecture alu_arch of alu_ent is
        begin
        process(x,y,a)
        begin
            case a is
                when "000"=>
                z<=x+y;
                reg_a_mov<="XXXXXXXX";
                reg_b_mov<="XXXXXXXX";
                sel<='1';
                when "001"=>
                z<=x-y;
                sel<='1';
                when "010"=>
                reg_a_mov<=y;
                reg_b_mov<=y;
                z<="XXXXXXXX";
                sel<='0';
                when "011"=>
                z<=x and y;
                sel<='1';
                when "100"=>
                z<=x or y;
                sel<='1';
                when "101"=>
                reg_b_mov<=x;
                reg_a_mov<=x;
                z<="XXXXXXXX";
                sel<='0';
                when others=>
                 z<="XXXXXXXX";
                sel<='1';
            end case;
      end process;
    end alu_arch;
--register
library ieee;
    use ieee.std_logic_arith.all;
    entity reg_new is
        end reg_new;
    architecture behav of reg_new is
        subtype cell is std_logic_vector(7 downto 0);
        type memarray is array(0 downto 0) of cell;
        signal mem:memarray;
        begin
            process(control)
                      begin
                        case control is
                            when "101"=>
                            data_out<=mem(0);
                            when "110"=>
                            mem(0)<=data_in;
                            data_out<=(others=>'Z');
                            when others=>
                        end case;
            end process;
        end behav;
Id have thought the error was self explanitory. You cannot assign to object of mode IN.
but sir
i have assigned the load and control using portmap.
it is similar to the d1 =>D2 case .
The error is not in the code you posted. You must be compiling different files.
sir
when i compile the alu program i get this as an error
# Compile of alu_collage.vhd failed with 1 errors.
when i double click to see the error there is no error and i get this.
vcom -work work -2002 -explicit -vopt H:/ollade_latest/alu_collage.vhd
Model Technology ModelSim SE vcom 6.2b Compiler 2006.07 Jul 31 2006
-- Loading package standard
-- Loading package std_logic_1164
-- Loading package std_logic_arith
-- Loading package std_logic_unsigned
-- Compiling entity alu_ent
-- Compiling architecture alu_arch of alu_ent
thank u sir.
there was another file with the same name.
now it is compiled.
now going to check if it is working as intended.
