reg[63:0]sum1,sum2;initialbegin sum1=mul[1][1]+mul[1][2]+mul[1][3]+mul[1][4]]+mul[1][5]+mul[1][6]+mul[1][7]+mul[1][8]+mul[2][1]+mul[2][2]+mul[2][3]+mul[2][4]]+mul[2][5]+mul[2][6]+mul[2][7]+mul[2][8]+mul[3][1]+mul[3][2]+mul[3][3]+mul[3][4]]+mul[3][5]+mul[3][6]+mul[3][7]+mul[3][8]+mul[4][1]+mul[4][2]+mul[4][3]+mul[4][4]]+mul[4][5]+mul[4][6]+mul[4][7]+mul[4][8];$display("the value of sum is %b",sum1);endinitialbegin
sum2=mul[1][1]+mul[1][2]+mul[1][3]+mul[1][4]]+mul[1][5]+mul[1][6]+mul[1][7]+mul[1][8]+mul[2][1]+mul[2][2]+mul[2][3]+mul[2][4]]+mul[2][5]+mul[2][6]+mul[2][7]+mul[2][8]+mul[3][1]+mul[3][2]+mul[3][3]+mul[3][4]]+mul[3][5]+mul[3][6]+mul[3][7]+mul[3][8]+mul[4][1]+mul[4][2]+mul[4][3]+mul[4][4]]+mul[4][5]+mul[4][6]+mul[4][7];$display("the value of sum is %b",sum2);end
and i get errors like :
1)expecting 'end', found '+'
2)unexpected token: '['
3)expecting 'endmodule', found '1'
Wow, thats a lot of adds.
You have a few extra ] in both initial blocks. Ill let you find them. I guess you did some copy and pasting and didnt bother to check.
To make life easier, never write terrible code like this again. Why not try using a for loop?
ive converted into a for loop... initially i used for and ended with many errors..so i decided to unroll them... and as i was rushing up i dint realize my mistake and posted it in here so that u people could help me... thanku anyways..
Error messages like "unexpected token: '['" are given with a source line number, you can easily narrow down the first error line, inspect it thoroughly and most likely fix it yourself.
The copy/paste of "[4]]" is the issue. you have [4]] a total of 8 times.
Depending on the tools, a for loop might not work for synthesis. I know older versions of vivado will not like a loop variable that isn't a genvar. It simply gives a warning of a simulation mismatch. It isn't clear if the initial block is generating an initial value for synthesis, or if this is just reporting logic for simulation.
