module stopwatch(
input clock,
input reset,
input start,
output a, b, c, d, e, f, g, dp,
output [3:0] an
reg [3:0] reg_d0, reg_d1, reg_d2, reg_d3; //registers that will hold the individual counts
reg [22:0] ticker; //23 bits needed to count up to 5M bits
wire click;
//the mod 5M clock to generate a tick ever 0.1 second
always @ (posedge clock or posedge reset)
begin
if(reset)
ticker <= 0;
else if(ticker == 5000000) //if it reaches the desired max value reset it
ticker <= 0;
else if(start) //only start if the input is set high
ticker <= ticker + 1;
end
assign click = ((ticker == 5000000)?1'b1:1'b0); //click to be assigned high every 0.1 second
begin
if (reset)
begin
reg_d0 <= 0;
reg_d1 <= 0;
reg_d2 <= 0;
reg_d3 <= 0;
end
else if (click) //increment at every click
begin
if(reg_d0 == 9) //xxx9 - the 0.1 second digit
begin //if_1
reg_d0 <= 0;
if (reg_d1 == 9) //xx99
begin // if_2
reg_d1 <= 0;
if (reg_d2 == 5) //x599 - the two digit seconds digits
begin //if_3
reg_d2 <= 0;
if(reg_d3 == 9) //9599 - The minute digit
reg_d3 <= 0;
else
reg_d3 <= reg_d3 + 1;
end
else //else_3
reg_d2 <= reg_d2 + 1;
end
else //else_2
reg_d1 <= reg_d1 + 1;
end
else //else_1
reg_d0 <= reg_d0 + 1;
end
end
//The Circuit for Multiplexing - Look at my other post for details on this
localparam N = 18;
reg [N-1:0]count;
begin
if (reset)
count <= 0;
else
count <= count + 1;
end
reg [6:0]sseg;
reg [3:0]an_temp;
reg reg_dp;
always @ (*)
begin
case(count[N-1:N-2])
2'b00 :
begin
sseg = reg_d0;
an_temp = 4'b1110;
reg_dp = 1'b1;
end
2'b01:
begin
sseg = reg_d1;
an_temp = 4'b1101;
reg_dp = 1'b0;
end
2'b10:
begin
sseg = reg_d2;
an_temp = 4'b1011;
reg_dp = 1'b1;
end
2'b11:
begin
sseg = reg_d3;
an_temp = 4'b0111;
reg_dp = 1'b0;
end
endcase
end
assign an = an_temp;
reg [6:0] sseg_temp;
always @ (*)
begin
case(sseg)
4'd0 : sseg_temp = 7'b1000000;
4'd1 : sseg_temp = 7'b1111001;
4'd2 : sseg_temp = 7'b0100100;
4'd3 : sseg_temp = 7'b0110000;
4'd4 : sseg_temp = 7'b0011001;
4'd5 : sseg_temp = 7'b0010010;
4'd6 : sseg_temp = 7'b0000010;
4'd7 : sseg_temp = 7'b1111000;
4'd8 : sseg_temp = 7'b0000000;
4'd9 : sseg_temp = 7'b0010000;
default : sseg_temp = 7'b0111111; //dash
endcase
end
assign {g, f, e, d, c, b, a} = sseg_temp;
assign dp = reg_dp;
endmodule
