djc
Advanced Member level 1
Here is my code for ATMEGA8 using Codevision for AVR for LCD programming,
However its giving an error in mentioned line that
function argument #1 of type 'flash unsigned char[2]' is incompatible with required parameter of type 'unsigned char'. What should be done for it.
This program was produced by the
CodeWizardAVR V2.03.4 Standard
Automatic Program Generator
© Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 3/18/2014
Author :
Company :
Comments:
Chip type : ATmega8
Program type : Application
Clock frequency : 8.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#include <delay.h>
#include <string.h>
#include <stdio.h>
#define LCD PORTC
#define RS PORTC.4
#define EN PORTC.5
void disp_cmd(unsigned char cmdout){
LCD = cmdout;
RS = 0;
EN = 1;
delay_us(10);
EN = 0;
void disp_dat(int dataout){
LCD = dataout;
RS = 1;
EN = 1;
delay_us(10);
EN = 0;
void LCD_Cmd(unsigned char data){
unsigned char val;
val = (data & 0xF0);
disp_cmd(val);
delay_us(10);
val = ((data<<4) & 0xF0);
disp_cmd(val);
delay_us(10);
void LCD_Dat(char data_1){
unsigned char val_1;
val_1 = (data_1 & 0xF0);
disp_dat(val_1);
delay_us(100);
val_1 = ((data_1<<4) & 0xF0);
disp_dat(val_1);
delay_us(100);
void LCD_Init(){
LCD_Cmd(0x01); //clear the screen
delay_ms(1);
LCD_Cmd(0x28); //4bit,2ine,5*7matrix
delay_us(100);
LCD_Cmd(0x02); //Cursor to top left character position
delay_ms(1);
LCD_Cmd(0x0F); //Turn On visible blinking block cursor
delay_us(100);
LCD_Cmd(0x06);
delay_us(100);
void Print_LCD(char *cptr){
while(*cptr != '\0'){
LCD_Dat(*cptr);
delay_us(100);
cptr++;
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0x00;
DDRC=0x7F;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
LCD_Init();
delay_ms(40);
while (1)
// Place your code here
Print_LCD("w"); /////////////////////Error line///////////////////////
