Hello,
I wrote a code for DFlipFlop in VHDL to be used in a TOP module. I want to put the placement constraints (LOC or RLOC) in VHDL code in order to put the FlipFlop in a specifc SLICE. Here is the DFlipFlop code:
Code VHDL - [expand] |
| entity DFF_1 is
Port ( D : in STD_LOGIC;
Q : out STD_LOGIC;
CLK : in STD_LOGIC; --clock
RESET : in STD_LOGIC); --reset
end DFF_1; |
architecture behavioral of DFF_1 is
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
| ATTRIBUTE LOC : STRING;
signal Qs : std_logic;
ATTRIBUTE LOC OF DFF : LABEL IS "SLICE_X"&INTEGER'image(12)&"Y"&INTEGER'image(30);
begin
process(CLK,RESET)
begin
if RESET = '1' then
Qs <= '0';
elsif RISING_EDGE(CLK) then
Qs <= D;
end if;
end process;
Q <= Qs ;
end behavioral; |
for the flipflop location constraints I wrote the following commands:
ATTRIBUTE LOC OF DFF : LABEL IS "SLICE_X"&INTEGER'image(12)&"Y"&INTEGER'image(30); |
Then I got the following error messages:
Code dot - [expand] |
| ERROR:HDLParsers:715 - "/export/tmp/darvishi/xilinx/BASIC_FPGA_TDC_Design_Me_part_by_part/TDC_FINAL_DESIGN_Sep_11th/Real_signal/My_idea/Design_with_ODC_injection/planAhead/Implemented modules/sources/DFF_1.vhd" Line 31. Attribute on units are only allowed on current unit.
ERROR:HDLParsers:900 - "/export/tmp/darvishi/xilinx/BASIC_FPGA_TDC_Design_Me_part_by_part/TDC_FINAL_DESIGN_Sep_11th/Real_signal/My_idea/Design_with_ODC_injection/planAhead/Implemented modules/sources/DFF_1.vhd" Line 52. The label DFF is not declared.
Then, I did the following trial:
ATTRIBUTE LOC OF DFF_1 : entity IS "SLICE_X12Y30";
and I got the same error.
Can anybody let me know how to solve it?
Thanks and Regards,
