abu9022
Member level 3
Hi Friends,
I have the following error, can you help me
VHDL file
mcore_te.vhd
leon_te.vhd
Error-[ANL-UNASSO-PORT] Illegal port association
leon/mcore_te.vhd, 36
TB_FUNC32
Unassociated port TE of mode IN in entity MCORE has no default value.
TB_FUNC32
TB_FUNC32
VHDL file
mcore_te.vhd
-- This file is a part of the LEON VHDL model
-- Copyright (C) 1999 European Space Agency (ESA)
-- This library is free software; you can redistribute it and/or
-- modify it under the terms of the GNU Lesser General Public
-- License as published by the Free Software Foundation; either
-- version 2 of the License, or (at your option) any later version.
-- See the file COPYING.LGPL for the full details of the license.
-- Entity: mcore
-- File: mcore.vhd
-- Author: Jiri Gaisler - Gaisler Reserch
-- Description: Module containing the processor, caches, memory controller
-- and standard peripherals
library IEEE;
use IEEE.std_logic_1164.all;
use work.target.all;
use work.config.all;
use work.iface.all;
use work.amba.all;
use work.ambacomp.all;
-- pragma translate_off
use work.debug.all;
-- pragma translate_on
entity mcore is [B][I]---------------------line 36[/I][/B]
port (
resetn : in std_logic;
clk : in clk_type;
te : in std_logic;-- := '1';
clkn : in clk_type;
pciclk : in clk_type;
memi : in memory_in_type;
memo : out memory_out_type;
ioi : in io_in_type;
ioo : out io_out_type;
pcii : in pci_in_type;
pcio : out pci_out_type;
dsi : in dsuif_in_type;
dso : out dsuif_out_type;
sdo : out sdram_out_type;
ethi : in eth_in_type;
etho : out eth_out_type;
cgo : in clkgen_out_type;
test : in std_logic
end;
architecture rtl of mcore is
component rstgen
port (
rstin : in std_logic;
pcirstin : in std_logic;
clk : in clk_type;
rstout : out std_logic;
pcirstout : out std_logic;
end component;
component dsu_mem
port (
clk : in clk_type;
dmi : in dsumem_in_type;
dmo : out dsumem_out_type
end component;
component proc
port (
rst : in std_logic;
clk : in clk_type; -- main clock
te : in std_logic;
clkn : in clk_type; -- inverted main clock
apbi : in apb_slv_in_type;
apbo : out apb_slv_out_type;
ahbi : in ahb_mst_in_type;
ahbo : out ahb_mst_out_type;
ahbsi : in ahb_slv_in_type;
iui : in iu_in_type;
iuo : out iu_out_type
end component;
--signal te_in : std_logic;
signal rst : std_logic;
signal iui : iu_in_type;
signal iuo : iu_out_type;
signal ahbsto: ahbstat_out_type;
signal mctrlo: mctrl_out_type;
signal wpo : wprot_out_type;
signal apbi : apb_slv_in_vector(0 to APB_SLV_MAX-1);
signal apbo : apb_slv_out_vector(0 to APB_SLV_MAX-1);
signal ahbmi : ahb_mst_in_vector(0 to AHB_MST_MAX-1);
signal ahbmo : ahb_mst_out_vector(0 to AHB_MST_MAX-1);
signal ahbsi : ahb_slv_in_vector(0 to AHB_SLV_MAX-1);
signal ahbso : ahb_slv_out_vector(0 to AHB_SLV_MAX);
signal dsuo : dsu_out_type;
signal dcomo : dcom_out_type;
signal irqi : irq_in_type;
signal irqo : irq_out_type;
signal irq2i : irq2_in_type;
signal irq2o : irq2_out_type;
signal timo : timers_out_type;
signal pioo : pio_out_type;
signal uart1i, uart2i : uart_in_type;
signal uart1o, uart2o : uart_out_type;
signal dmi : dsumem_in_type;
signal dmo : dsumem_out_type;
signal pciirq : std_logic;
signal ethirq : std_logic;
signal pcirst : std_logic;
signal pciahb2: ahb_mst_out_type;
begin
-- reset generator
reset0 : rstgen port map (resetn, pcii.pci_rst_in_n, clk,
pciclk, rst, pcirst, cgo);
-- AHB bus --
-- AHB arbiter/decoder
ahb0 : ahbarb
generic map (masters => AHB_MASTERS, defmast => AHB_DEFMST)
port map (rst, clk, ahbmi(0 to AHB_MASTERS-1),
ahbmo(0 to AHB_MASTERS-1), ahbsi, ahbso);
-- AHB/APB bridge
apb0 : apbmst
port map (rst, clk, ahbsi(1), ahbso(1), apbi, apbo);
-- processor and cache sub-system
proc0 : proc port map (
rst, clk, te, clkn, apbi(2), apbo(2), ahbmi(0), ahbmo(0),
ahbsi(0), iui, iuo);
-- debug support unit
dsugen : if DEBUG_UNIT generate
dsu0 : dsu port map ( rst, clk, ahbmi(0), ahbsi(2), ahbso(2),
dsi.dsui, dsuo, iuo.debug, iui.debug, irqo, dmi, dmo);
dso.dsuo <= dsuo;
dsum0 : dsu_mem port map ( clk, dmi, dmo);
end generate;
dcomgen : if DEBUG_UNIT generate
dcom0 : dcom
port map ( rst, clk, dsi.dcomi, dcomo, dsuo, apbi(11),
apbo(11), ahbmi(AHB_MASTERS-1), ahbmo(AHB_MASTERS-1) );
dso.dcomo <= dcomo;
end generate;
-- sram/prom/sdram memory controller
mctrl0 : mctrl port map (
rst => rst, clk=> clk, memi => memi, memo => memo,
ahbsi => ahbsi(0), ahbso => ahbso(0), apbi => apbi(0), apbo => apbo(0),
pioo => pioo, wpo => wpo, sdo => sdo, mctrlo => mctrlo);
-- AHB ram
aram0 : if AHBRAMEN generate
aram : ahbram generic map (AHBRAM_BITS)
port map (rst, clk, ahbsi(4), ahbso(4));
end generate;
-- AHB write protection
wp0 : if WPROTEN generate
wpm : wprot port map (
rst => rst, clk => clk, wpo => wpo, ahbsi => ahbsi(0),
apbi => apbi(3), apbo => apbo(3));
end generate;
wp1 : if not WPROTEN generate apbo(3).prdata <= (others => '0'); end generate;
-- AHB status register
as0 : if AHBSTATEN generate
asm : ahbstat port map (
rst => rst, clk => clk, ahbmi => ahbmi(0), ahbsi => ahbsi(0),
apbi => apbi(1), apbo => apbo(1), ahbsto => ahbsto);
end generate;
as1 : if not AHBSTATEN generate
apbo(1).prdata <= (others => '0'); ahbsto.ahberr <= '0';
end generate;
-- Optional PCI core
pci0 : if PCIEN generate
pci0 : pci
port map ( resetn => rst, clk => clk, pciclk => pciclk,
pcirst => pcirst, pcii => pcii, pcio => pcio,
ahbmi1 => ahbmi(1), ahbmo1 => ahbmo(1),
ahbsi => ahbsi(3), ahbso => ahbso(3),
apbi => apbi(12), apbo => apbo(12), irq => pciirq);
end generate;
nopci : if not PCIEN generate pciirq <= '0'; end generate;
eth0 : if ETHEN generate
eth0 : eth_oc
port map ( rst => rst, clk => clk,
ahbsi => ahbsi(5), ahbso => ahbso(5),
ahbmi => ahbmi(PCIMASTERS+1), ahbmo => ahbmo(PCIMASTERS+1),
eneti => ethi, eneto => etho,
irq => ethirq);
end generate;
noeth : if not ETHEN generate ethirq <= '0'; end generate;
-- drive unused part of the AHB bus to stop some stupid synthesis tools
-- from inserting tri-state buffers (!) DISABLED
-- ahbdrv : for i in 0 to AHB_SLV_MAX-1 generate
-- u0 : if not AHB_SLVTABLE(i).enable and (AHB_SLVTABLE(i).index /= 0) generate
-- ahbso(AHB_SLVTABLE(i).index).hready <= '0';
-- ahbso(AHB_SLVTABLE(i).index).hresp <= "--";
-- ahbso(AHB_SLVTABLE(i).index).hrdata <= (others => '-');
-- ahbso(AHB_SLVTABLE(i).index).hsplit <= (others => '-');
-- end generate;
-- end generate;
-- APB bus --
pci_arb0 : if PCIARBEN generate
pciarb : pci_arb
port map (
clk => pciclk, rst_n => pcirst,
req_n => ioi.pci_arb_req_n, frame_n => pcii.pci_frame_in_n,
gnt_n => ioo.pci_arb_gnt_n, pclk => clk,
prst_n => rst, pbi => apbi(13), pbo => apbo(13)
end generate;
-- LEON configuration register
lc0 : if CFGREG generate
lcm : lconf port map (rst => rst, apbo => apbo(4));
end generate;
-- timers (and watchdog)
timers0 : timers
port map (rst => rst, clk => clk, apbi => apbi(5),
apbo => apbo(5), timo => timo, dsuo => dsuo);
-- UARTS
-- This stupidity exists because synopsys DC is not capable of
-- handling record elements in port maps. Sad really ...
uart1i.rxd <= pioo.rxd(0); uart1i.ctsn <= pioo.ctsn(0);
uart2i.rxd <= pioo.rxd(1); uart2i.ctsn <= pioo.ctsn(1);
uart1i.scaler <= pioo.io8lsb; uart2i.scaler <= pioo.io8lsb;
uart1 : uart port map (
rst => rst, clk => clk, apbi => apbi(6), apbo => apbo(6),
uarti => uart1i, uarto => uart1o);
uart2 : uart port map (
rst => rst, clk => clk, apbi => apbi(7), apbo => apbo(7),
uarti => uart2i, uarto => uart2o);
-- interrupt controller
irqctrl0 : irqctrl
port map (rst => rst, clk => clk, apbi => apbi(8),
apbo => apbo(8), irqi => irqi, irqo => irqo);
irqi.intack <= iuo.intack; irqi.irl <= iuo.irqvec; iui.irl <= irqo.irl;
-- optional secondary interrupt controller
i2 : if IRQ2EN generate
irqctrl1 : irqctrl2
port map (rst => rst, clk => clk, apbi => apbi(10),
apbo => apbo(10), irqi => irq2i, irqo => irq2o);
end generate;
-- parallel I/O port
ioport0 : ioport
port map (rst => rst, clk => clk, apbi => apbi(9), apbo => apbo(9),
uart1o => uart1o, uart2o => uart2o, mctrlo => mctrlo,
ioi => ioi, pioo => pioo);
-- drive unused part of the APB bus to stop some stupid synthesis tools
-- apbdrv : for i in 0 to APB_SLV_MAX-1 generate
-- u0 : if not APB_TABLE(i).enable and (APB_TABLE(i).index /= 0) generate
-- apbo( APB_TABLE(i).index).prdata <= (others => '-');
-- end generate;
-- end generate;
-- IRQ assignments, add you mapping below
irqi.irq(15) <= '0'; -- unmaskable irq
irqi.irq(14) <= pciirq;
irqi.irq(13) <= '0';
irqi.irq(12) <= ethirq;
irqi.irq(11) <= dsuo.ntrace when DEBUG_UNIT else '0';
irqi.irq(10) <= irq2o.irq when IRQ2EN else '0';
irqi.irq(9) <= timo.irq(1); -- timer 2
irqi.irq(8) <= timo.irq(0); -- timer 1
irqi.irq(7 downto 4) <= pioo.irq; -- I/O port interrupts
irqi.irq(3) <= uart1o.irq; -- UART 1
irqi.irq(2) <= uart2o.irq; -- UART 2
irqi.irq(1) <= ahbsto.ahberr; -- AHB error
-- additional 32 interrupts for secondary interrupt controller
irq2i.irq <= (others => '0');
-- drive outputs
ioo.piol <= pioo.piol(15 downto 0);
ioo.piodir <= pioo.piodir(15 downto 0);
ioo.wdog <= timo.wdog;
ioo.errorn <= iuo.error;
-- disassambler
trace0 : trace(iuo.debug, (test = '1'));
end ;
leon_te.vhd
-- Entity: leon
-- File: leon.vhd
-- Author: Jiri Gaisler - ESA/ESTEC
-- Description: Complete processor
library IEEE;
use work.iface.all;
use work.tech_map.all;
use work.debug.all;
entity leon is
port (
resetn : in std_logic; -- system signals
clk : in std_logic;
te : in std_logic;
pllref : in std_logic;
plllock : out std_logic;
errorn : out std_logic;
address : out std_logic_vector(27 downto 0); -- memory bus
data : inout std_logic_vector(31 downto 0);
ramsn : out std_logic_vector(4 downto 0);
ramoen : out std_logic_vector(4 downto 0);
rwen : inout std_logic_vector(3 downto 0);
romsn : out std_logic_vector(1 downto 0);
iosn : out std_logic;
oen : out std_logic;
read : out std_logic;
writen : inout std_logic;
brdyn : in std_logic;
bexcn : in std_logic;
-- sdram i/f
sdcke : out std_logic_vector ( 1 downto 0); -- clk en
sdcsn : out std_logic_vector ( 1 downto 0); -- chip sel
sdwen : out std_logic; -- write en
sdrasn : out std_logic; -- row addr stb
sdcasn : out std_logic; -- col addr stb
sddqm : out std_logic_vector ( 7 downto 0); -- data i/o mask
sdclk : out std_logic; -- sdram clk output
sa : out std_logic_vector(14 downto 0); -- optional sdram address
sd : inout std_logic_vector(63 downto 0); -- optional sdram data
pio : inout std_logic_vector(15 downto 0); -- I/O port
wdogn : out std_logic; -- watchdog output
dsuen : in std_logic;
dsutx : out std_logic;
dsurx : in std_logic;
dsubre : in std_logic;
dsuact : out std_logic;
test : in std_logic
end;
architecture rtl of leon is
component mcore
port (
clk : in clk_type;
te : in std_logic;
clkn : in clk_type;
test : in std_logic
end component;
signal gnd, clko, sdclkl, resetno : std_logic;
signal clkm, clkn, pciclk : clk_type;
signal te : std_logic;
signal memi : memory_in_type;
signal memo : memory_out_type;
signal ioi : io_in_type;
signal ioo : io_out_type;
signal pcii : pci_in_type;
signal pcio : pci_out_type;
signal dsi : dsuif_in_type;
signal dso : dsuif_out_type;
signal sdo : sdram_out_type;
signal ethi : eth_in_type;
signal etho : eth_out_type;
signal cgi : clkgen_in_type;
signal cgo : clkgen_out_type;
--attribute keep_hierarchy : String;
--attribute keep_hierarchy of rtl : architecture is "yes";
begin
gnd <= '0';
cgi.pllctrl <= "00"; cgi.pllrst <= resetno; cgi.pllref <= pllref;
-- main processor core
mcore0 : mcore
port map (
resetn => resetno, clk => clkm, te => te, clkn => clkn, pciclk => pciclk,
memi => memi, memo => memo, ioi => ioi, ioo => ioo,
pcii => pcii, pcio => pcio, dsi => dsi, dso => dso, sdo => sdo,
ethi => ethi, etho => etho, cgo => cgo, test => test );
-- clock generator
clkgen0 : clkgen
port map ( clko, clko, clkm, clkn, sdclkl, pciclk, cgi, cgo);
-- pads
-- clk_pad : inpad port map (clk, clko); -- clock
clko <= clk; -- avoid buffering during synthesis
reset_pad : smpad port map (resetn, resetno); -- reset
brdyn_pad : inpad port map (brdyn, memi.brdyn); -- bus ready
bexcn_pad : inpad port map (bexcn, memi.bexcn); -- bus exception
error_pad : outpad generic map (2) port map (ioo.errorn, errorn); -- cpu error mode
d_pads: for i in 0 to 31 generate -- data bus
d_pad : iopad generic map (3) port map (memo.data(i), memo.bdrive((31-i)/8), memi.data(i), data(i));
end generate;
pio_pads : for i in 0 to 15 generate -- parallel I/O port
pio_pad : smiopad generic map (2) port map (ioo.piol(i), ioo.piodir(i), ioi.piol(i), pio(i));
end generate;
rwen_pads : for i in 0 to 3 generate -- ram write strobe
rwen_pad : iopad generic map (2) port map (memo.wrn(i), gnd, memi.wrn(i), rwen(i));
end generate;
-- I/O write strobe
writen_pad : iopad generic map (2) port map (memo.writen, gnd, memi.writen, writen);
a_pads: for i in 0 to 27 generate -- memory address
a_pad : outpad generic map (3) port map (memo.address(i), address(i));
end generate;
ramsn_pads : for i in 0 to 4 generate -- ram oen/rasn
ramsn_pad : outpad generic map (2) port map (memo.ramsn(i), ramsn(i));
end generate;
ramoen_pads : for i in 0 to 4 generate -- ram chip select
ramoen_pad : outpad generic map (2) port map (memo.ramoen(i), ramoen(i));
end generate;
romsn_pads : for i in 0 to 1 generate -- rom chip select
romsn_pad : outpad generic map (2) port map (memo.romsn(i), romsn(i));
end generate;
read_pad : outpad generic map (2) port map (memo.read, read); -- memory read
oen_pad : outpad generic map (2) port map (memo.oen, oen); -- memory oen
iosn_pad : outpad generic map (2) port map (memo.iosn, iosn); -- I/O select
wd : if WDOGEN generate
wdogn_pad : odpad generic map (2) port map (ioo.wdog, wdogn); -- watchdog output
end generate;
ds : if DEBUG_UNIT generate
dsuen_pad : inpad port map (dsuen, dsi.dsui.dsuen); -- DSU enable
dsutx_pad : outpad generic map (1) port map (dso.dcomo.dsutx, dsutx);
dsurx_pad : inpad port map (dsurx, dsi.dcomi.dsurx); -- DSU receive data
dsubre_pad : inpad port map (dsubre, dsi.dsui.dsubre); -- DSU break
dsuact_pad : outpad generic map (1) port map (dso.dsuo.dsuact, dsuact);
end generate;
sdr : if SDRAMEN generate
cs_pads: for i in 0 to 1 generate
sdcke_pad : outpad generic map (2) port map (sdo.sdcke(i), sdcke(i));
sdcsn_pad : outpad generic map (2) port map (sdo.sdcsn(i), sdcsn(i));
end generate;
sdwen_pad : outpad generic map (2) port map (sdo.sdwen, sdwen);
sdrasn_pad : outpad generic map (2) port map (sdo.rasn, sdrasn);
sdcasn_pad : outpad generic map (2) port map (sdo.casn, sdcasn);
-- sdclk_pad : outpad generic map (2) port map (sdclkl, sdclk);
sdclk <= sdclkl; -- disable pad for simulation
dqm_pads: for i in 0 to 3 generate
sddqm_pad : outpad generic map (2) port map (sdo.dqm(i), sddqm(i));
end generate;
sb : if SDSEPBUS generate
sa_pads: for i in 0 to 14 generate -- memory address
p : outpad generic map (2) port map (memo.sa(i), sa(i));
end generate;
sd_pads: for i in 0 to 31 generate -- data bus
p : iopad generic map (3) port map (memo.data(i), memo.bdrive((31-i)/8), memi.sd(i), sd(i));
end generate;
sb : if BUS64 generate
dqm_pads: for i in 4 to 7 generate
end generate;
sd_pads: for i in 32 to 63 generate -- data bus
p : iopad generic map (3) port map (memo.data(i-32), memo.bdrive((63-i)/8), memi.sd(i), sd(i));
end generate;
end generate;
end generate;
end generate;
pl : if TARGET_CLK /= gen generate
plllock_pad : outpad generic map (2) port map (cgo.clklock, plllock);
end generate;
end ;
