Error HFSS 15 on CENTOS 6 (redhat 6)
pit87
Newbie level 3
Newbie level 3
when i run hfss (after a good install of hfss 15)
### Warning: Unable to determine Red Hat Enterprise Linux version number.
Currently-supported Linux versions include:
- Red Hat Enterprise Linux 64-bit: Versions v5 and v6
- SuSE Linux Enterprise Server 64-bit: Version 11
* /users/cao/hfss15/hfss15.0/Linux/.setup_runtime: line 8: 55330 Erreur de segmentation (core dumped) perl -e 'alarm shift; exec @ARGV' "$@"
HFSS 15.0 Product Configuration
Hostname: dragonne
User: pit
> Running first-time configuration...
- Verifying all software dependencies are available: ERROR
* The following additional errors were detected:
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/mttv.o (ldd error): n'est pas un exécutable dynamique
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/pc_long_ext.o (ldd error): n'est pas un exécutable dynamique
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/pcautodbl_isi8.o (ldd error): n'est pas un exécutable dynamique
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/pcautodbl_isr16.o (ldd error): n'est pas un exécutable dynamique
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/pcautodbl_isr8.o (ldd error): n'est pas un exécutable dynamique
/users/cao/hfss15/hfss15.0/Linux/common/fluent_mpi/multiport/mpi/lnamd64/pcmpi/lib/linux_amd64/tv.o (ldd error): n'est pas un exécutable dynamique
Full ldd output is available at: /tmp/pit.AnsysEM.DependencyOutput.dHc5oV.log
*** Error: Not all dependencies were found. ***
you have a solution ?
anyone ?
UP !! UP !! please ... HFSS15 don't work on redhat 6 ( 6.4 )
The message "Error: Not all dependencies were found." indicates that something is missing. Can you check the dependencies?
Perhaps talk to Ansys.
This is what is going on most likely. There is a Linux Installation document found on the ANSYS Customer Portal @ support.ansys.com. I suggest you get this document, install all the dependencies, and you should be good to go.
I think all the dependencies are installed. The problem is a segmentation fault during the verification phase. AND/OR this error of (ldd error) is not a dynamic executable / library.
You probably need to install the 32bit compatible libraries on Centos, perhaps something is missing that is making ldd fail. Alternatively, those libraries look like part of the message passing interface (MPI) used for the domain decomposition.. if you don't need it you could try setting the ANS_NODEPDCHECK environment variable to skip the dependency checks.
Bill
[Solved] Re: Error HFSS 15 on CENTOS 6 (redhat 6)
Bill
a solution with on HFSS 15 or 16 (export this variable) :
export ANS_NODEPCHECK=1
export ANS_IGNOREOS=1
and launch the app
Thank you
