ERROR: FR_INT_ERR in sd card atmega128
Osawa_Odessa
Banned
Hello,
I am sorry for post this question again in another forum.
I use the code bellow for atmega128 to read and write to sd card. When i run the code i get the error:
COM1 OK Init OK
Logical drive 0: mounted OK
0:/file.txt
ERROR: FR_INT_ERR
I used uart to find out that the error is caused by f_open but i can't specify exactly what is causing it and how to fix it. Can anyone help me?
This is the code, i use codevisionavr:
/  FatFs - FAT file system module include file  R0.07e       (C)ChaN, 2009
/ FatFs module is an open source software to implement FAT file system to
/ small embedded systems. This is a free software and is opened for education,
/ research and commercial developments under license policy of following terms.
/  Copyright (C) 2009, ChaN, all right reserved.
/ * The FatFs module is a free software and there is NO WARRANTY.
/ * No restriction on use. You can use, modify and redistribute it for
/   personal, non-profit or commercial product UNDER YOUR RESPONSIBILITY.
/ * Redistributions of source code must retain the above copyright notice.
Modified and optimized for the CodeVisionAVR V2.0 C Compiler
by Pavel Haiduc, HP InfoTech s.r.l. (C) 2009-2011
V1.0 July 2009 - initial R0.07c
V1.1 May  2011 - updated to R0.07e, improved speed and code size
/ FatFs Configuration Options
/ CAUTION! Do not forget to make clean the project after any changes to
/ the configuration options.
#ifndef _FATFS
#define _FATFS	0x007E
#define _FS_READONLY	0
/* Setting _FS_READONLY to 1 defines read only configuration. This removes
/  writing functions, f_write, f_sync, f_unlink, f_mkdir, f_chmod, f_rename,
/  f_truncate and useless f_getfree. */
#define _FS_MINIMIZE	0
/* The _FS_MINIMIZE option defines minimization level to remove some functions.
/   0: Full function.
/   1: f_stat, f_getfree, f_unlink, f_mkdir, f_chmod, f_truncate and f_rename
/      are removed.
/   2: f_opendir and f_readdir are removed in addition to level 1.
/   3: f_lseek is removed in addition to level 2. */
#define	_FS_TINY	0
/* When _FS_TINY is set to 1, FatFs uses the sector buffer in the file system
/  object instead of the sector buffer in the individual file object for file
/  data transfer. This reduces memory consumption 512 bytes each file object. */
#define	_USE_MKFS	0
/* To enable f_mkfs function, set _USE_MKFS to 1 and set _FS_READONLY to 0 */
#define	_USE_FORWARD	0
/* To enable f_forward function, set _USE_FORWARD to 1 and set _FS_TINY to 1. */
#define _CODE_PAGE 1 /* ASCII */
/* The _CODE_PAGE specifies the OEM code page to be used on the target system.
/   1 - ASCII (Valid for only non LFN cfg.)
/   932  - Japanese Shift-JIS (DBCS, OEM, Windows)
/   936  - Simplified Chinese GBK (DBCS, OEM, Windows)
/   949  - Korean (DBCS, OEM, Windows)
/   950  - Traditional Chinese Big5 (DBCS, OEM, Windows)
/   1250 - Central Europe (Windows)
/   1251 - Cyrillic (Windows)
/   1252 - Latin 1 (Windows)
/   1253 - Greek (Windows)
/   1254 - Turkish (Windows)
/   1255 - Hebrew (Windows)
/   1256 - Arabic (Windows)
/   1257 - Baltic (Windows)
/   1258 - Vietnam (OEM, Windows)
/   437  - U.S. (OEM)
/   720  - Arabic (OEM)
/   737  - Greek (OEM)
/   775  - Baltic (OEM)
/   850  - Multilingual Latin 1 (OEM)
/   858  - Multilingual Latin 1 + Euro (OEM)
/   852  - Latin 2 (OEM)
/   855  - Cyrillic (OEM)
/   866  - Russian (OEM)
/   857  - Turkish (OEM)
/   862  - Hebrew (OEM)
/   874  - Thai (OEM, Windows)
#define	_USE_LFN	0  /* NOT SUPPORTED */
#define	_MAX_LFN	255		/* Maximum LFN length to handle (max:255) */
/* _USE_LFN option switches the LFN support.
/   0: Disable LFN.
/   1: Enable LFN with static working buffer on the bss. NOT REENTRANT.
/   2: Enable LFN with dynamic working buffer on the caller's STACK.
/  The working buffer occupies (_MAX_LFN + 1) * 2 bytes. When enabling LFN,
/  Unicode handling functions ff_convert() and ff_wtoupper() must be added
/  to the project. */
#define _LFN_UNICODE 0 /* NOT SUPPORTED */
/* Enable unicode support for long file names */
#define _FS_RPATH	1
/* When _FS_RPATH is set to 1, relative path feature is enabled and f_chdir,
/  f_chdrive function are available.
/  Note that output of the f_readdir fnction is affected by this option. */
#define _FS_REENTRANT	0
#define _TIMEOUT		1000	/* Timeout period in unit of time ticks of the OS */
#define	_SYNC_t		HANDLE	/* Type of sync object used on the OS. e.g. HANDLE, OS_EVENT*, ID and etc.. */
/* To make the FatFs module re-entrant, set _FS_REENTRANT to 1 and add user
/  provided synchronization handlers, ff_req_grant, ff_rel_grant, ff_del_syncobj
/  and ff_cre_syncobj function to the project. */
#define _DRIVES		1
/* Number of volumes (logical drives) to be used. */
#define	_MAX_SS		512
/* Maximum sector size to be handled. (512/1024/2048/4096) */
/* Usually set 512 for memory card and hard disk but 1024 for floppy disk, 2048 for MO disk */
/* When _MAX_SS > 512, GET_SECTOR_SIZE must be implemented to disk_ioctl() */
#define	_MULTI_PARTITION	0
/* When _MULTI_PARTITION is set to 0, each volume is bound to the same physical
/ drive number and can mount only first primary partition. When it is set to 1,
/ each volume is tied to the partitions listed in Drives[]. */
/* End of configuration options. Do not change followings without care.     */
#include <sdcard.h>
/* DBCS code ranges and SBCS extend char conversion table */
#if _CODE_PAGE == 932	/* Japanese Shift-JIS */
#define _DF1S	0x81	/* DBC 1st byte range 1 start */
#define _DF1E	0x9F	/* DBC 1st byte range 1 end */
#define _DF2S	0xE0	/* DBC 1st byte range 2 start */
#define _DF2E	0xFC	/* DBC 1st byte range 2 end */
#define _DS1S	0x40	/* DBC 2nd byte range 1 start */
#define _DS1E	0x7E	/* DBC 2nd byte range 1 end */
#define _DS2S	0x80	/* DBC 2nd byte range 2 start */
#define _DS2E	0xFC	/* DBC 2nd byte range 2 end */
#elif _CODE_PAGE == 936	/* Simplified Chinese GBK */
#define _DF1S	0x81
#define _DF1E	0xFE
#define _DS1S	0x40
#define _DS1E	0x7E
#define _DS2S	0x80
#define _DS2E	0xFE
#elif _CODE_PAGE == 949	/* Korean */
#define _DF1S	0x81
#define _DF1E	0xFE
#define _DS1S	0x41
#define _DS1E	0x5A
#define _DS2S	0x61
#define _DS2E	0x7A
#define _DS3S	0x81
#define _DS3E	0xFE
#elif _CODE_PAGE == 950	/* Traditional Chinese Big5 */
#define _DF1S	0x81
#define _DF1E	0xFE
#define _DS1S	0x40
#define _DS1E	0x7E
#define _DS2S	0xA1
#define _DS2E	0xFE
#elif _CODE_PAGE == 437	/* U.S. (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x9A,0x90,0x41,0x8E,0x41,0x8F,0x80,0x45,0x45,0x45,0x49,0x49,0x49,0x8E,0x8F,0x90,0x92,0x92,0x4F,0x99,0x4F,0x55,0x55,0x59,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F, \
				0x41,0x49,0x4F,0x55,0xA5,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0x21,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF, \
				0xE0,0xE1,0xE2,0xE3,0xE4,0xE5,0xE6,0xE7,0xE8,0xE9,0xEA,0xEB,0xEC,0xED,0xEE,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 720	/* Arabic (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x45,0x41,0x84,0x41,0x86,0x43,0x45,0x45,0x45,0x49,0x49,0x8D,0x8E,0x8F,0x90,0x92,0x92,0x93,0x94,0x95,0x49,0x49,0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F, \
				0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
#elif _CODE_PAGE == 737	/* Greek (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x92,0x92,0x93,0x94,0x95,0x96,0x97,0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87, \
				0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0xAA,0x92,0x93,0x94,0x95,0x96,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0x97,0xEA,0xEB,0xEC,0xE4,0xED,0xEE,0xE7,0xE8,0xF1,0xEA,0xEB,0xEC,0xED,0xEE,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 775	/* Baltic (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x9A,0x91,0xA0,0x8E,0x95,0x8F,0x80,0xAD,0xED,0x8A,0x8A,0xA1,0x8D,0x8E,0x8F,0x90,0x92,0x92,0xE2,0x99,0x95,0x96,0x97,0x97,0x99,0x9A,0x9D,0x9C,0x9D,0x9E,0x9F, \
				0xA0,0xA1,0xE0,0xA3,0xA3,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xB5,0xB6,0xB7,0xB8,0xBD,0xBE,0xC6,0xC7,0xA5,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF, \
				0xE0,0xE1,0xE2,0xE3,0xE5,0xE5,0xE6,0xE3,0xE8,0xE8,0xEA,0xEA,0xEE,0xED,0xEE,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 850	/* Multilingual Latin 1 (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x9A,0x90,0xB6,0x8E,0xB7,0x8F,0x80,0xD2,0xD3,0xD4,0xD8,0xD7,0xDE,0x8E,0x8F,0x90,0x92,0x92,0xE2,0x99,0xE3,0xEA,0xEB,0x59,0x99,0x9A,0x9D,0x9C,0x9D,0x9E,0x9F, \
				0xB5,0xD6,0xE0,0xE9,0xA5,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0x21,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC7,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF, \
				0xE0,0xE1,0xE2,0xE3,0xE5,0xE5,0xE6,0xE7,0xE7,0xE9,0xEA,0xEB,0xED,0xED,0xEE,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 852	/* Latin 2 (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x9A,0x90,0xB6,0x8E,0xDE,0x8F,0x80,0x9D,0xD3,0x8A,0x8A,0xD7,0x8D,0x8E,0x8F,0x90,0x91,0x91,0xE2,0x99,0x95,0x95,0x97,0x97,0x99,0x9A,0x9B,0x9B,0x9D,0x9E,0x9F, \
				0xB5,0xD6,0xE0,0xE9,0xA4,0xA4,0xA6,0xA6,0xA8,0xA8,0xAA,0x8D,0xAC,0xB8,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBD,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC6,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD1,0xD1,0xD2,0xD3,0xD2,0xD5,0xD6,0xD7,0xB7,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF, \
				0xE0,0xE1,0xE2,0xE3,0xE3,0xD5,0xE6,0xE6,0xE8,0xE9,0xE8,0xEB,0xED,0xED,0xDD,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xEB,0xFC,0xFC,0xFE,0xFF}
#elif _CODE_PAGE == 855	/* Cyrillic (OEM) */
#define _DF1S	0
#define _EXCVT {0x81,0x81,0x83,0x83,0x85,0x85,0x87,0x87,0x89,0x89,0x8B,0x8B,0x8D,0x8D,0x8F,0x8F,0x91,0x91,0x93,0x93,0x95,0x95,0x97,0x97,0x99,0x99,0x9B,0x9B,0x9D,0x9D,0x9F,0x9F, \
				0xA1,0xA1,0xA3,0xA3,0xA5,0xA5,0xA7,0xA7,0xA9,0xA9,0xAB,0xAB,0xAD,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB6,0xB6,0xB8,0xB8,0xB9,0xBA,0xBB,0xBC,0xBE,0xBE,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC7,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD1,0xD1,0xD3,0xD3,0xD5,0xD5,0xD7,0xD7,0xDD,0xD9,0xDA,0xDB,0xDC,0xDD,0xE0,0xDF, \
				0xE0,0xE2,0xE2,0xE4,0xE4,0xE6,0xE6,0xE8,0xE8,0xEA,0xEA,0xEC,0xEC,0xEE,0xEE,0xEF,0xF0,0xF2,0xF2,0xF4,0xF4,0xF6,0xF6,0xF8,0xF8,0xFA,0xFA,0xFC,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 857	/* Turkish (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x9A,0x90,0xB6,0x8E,0xB7,0x8F,0x80,0xD2,0xD3,0xD4,0xD8,0xD7,0x98,0x8E,0x8F,0x90,0x92,0x92,0xE2,0x99,0xE3,0xEA,0xEB,0x98,0x99,0x9A,0x9D,0x9C,0x9D,0x9E,0x9E, \
				0xB5,0xD6,0xE0,0xE9,0xA5,0xA5,0xA6,0xA6,0xA8,0xA9,0xAA,0xAB,0xAC,0x21,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0xE0,0xE1,0xE2,0xE3,0xE5,0xE5,0xE6,0xE7,0xE8,0xE9,0xEA,0xEB,0xDE,0x59,0xEE,0xEF,0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 858	/* Multilingual Latin 1 + Euro (OEM) */
#define _DF1S	0
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC7,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD1,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF, \
#elif _CODE_PAGE == 862	/* Hebrew (OEM) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F, \
#elif _CODE_PAGE == 866	/* Russian (OEM) */
#define _DF1S	0
				0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0x90,0x91,0x92,0x93,0x9d,0x95,0x96,0x97,0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F,0xF0,0xF0,0xF2,0xF2,0xF4,0xF4,0xF6,0xF6,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 874	/* Thai (OEM, Windows) */
#define _DF1S	0
#elif _CODE_PAGE == 1250 /* Central Europe (Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x8A,0x9B,0x8C,0x8D,0x8E,0x8F, \
				0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xA3,0xB4,0xB5,0xB6,0xB7,0xB8,0xA5,0xAA,0xBB,0xBC,0xBD,0xBC,0xAF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xF7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xFF}
#elif _CODE_PAGE == 1251 /* Cyrillic (Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x82,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x80,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x8A,0x9B,0x8C,0x8D,0x8E,0x8F, \
				0xA0,0xA2,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB2,0xA5,0xB5,0xB6,0xB7,0xA8,0xB9,0xAA,0xBB,0xA3,0xBD,0xBD,0xAF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF}
#elif _CODE_PAGE == 1252 /* Latin 1 (Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0xAd,0x9B,0x8C,0x9D,0xAE,0x9F, \
				0xA0,0x21,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xF7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0x9F}
#elif _CODE_PAGE == 1253 /* Greek (Windows) */
#define _DF1S	0
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xA2,0xB8,0xB9,0xBA, \
				0xE0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,0xD0,0xD1,0xF2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xFB,0xBC,0xFD,0xBF,0xFF}
#elif _CODE_PAGE == 1254 /* Turkish (Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x8A,0x9B,0x8C,0x9D,0x9E,0x9F, \
#elif _CODE_PAGE == 1255 /* Hebrew (Windows) */
#define _DF1S	0
#elif _CODE_PAGE == 1256 /* Arabic (Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9A,0x9B,0x8C,0x9D,0x9E,0x9F, \
				0x41,0xE1,0x41,0xE3,0xE4,0xE5,0xE6,0x43,0x45,0x45,0x45,0x45,0xEC,0xED,0x49,0x49,0xF0,0xF1,0xF2,0xF3,0x4F,0xF5,0xF6,0xF7,0xF8,0x55,0xFA,0x55,0x55,0xFD,0xFE,0xFF}
#elif _CODE_PAGE == 1257 /* Baltic (Windows) */
#define _DF1S	0
				0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xA8,0xB9,0xAA,0xBB,0xBC,0xBD,0xBE,0xAF, \
#elif _CODE_PAGE == 1258 /* Vietnam (OEM, Windows) */
#define _DF1S	0
#define _EXCVT {0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9A,0x9B,0xAC,0x9D,0x9E,0x9F, \
				0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xEC,0xCD,0xCE,0xCF,0xD0,0xD1,0xF2,0xD3,0xD4,0xD5,0xD6,0xF7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xFE,0x9F}
#elif _CODE_PAGE == 1	/* ASCII (for only non-LFN cfg) */
#define _DF1S	0
#else
#error Unknown code page
#endif
/* Character code support macros */
#define IsUpper(c)	(((c)>='A')&&((c)<='Z'))
#define IsLower(c)	(((c)>='a')&&((c)<='z'))
#define IsDigit(c)	(((c)>='0')&&((c)<='9'))
#if _DF1S	/* DBCS configuration */
#if _DF2S	/* Two 1st byte areas */
#define IsDBCS1(c)	(((unsigned char)(c) >= _DF1S && (unsigned char)(c) <= _DF1E) || ((unsigned char)(c) >= _DF2S && (unsigned char)(c) <= _DF2E))
#else		/* One 1st byte area */
#define IsDBCS1(c)	((unsigned char)(c) >= _DF1S && (unsigned char)(c) <= _DF1E)
#endif
#if _DS3S	/* Three 2nd byte areas */
#define IsDBCS2(c)	(((unsigned char)(c) >= _DS1S && (unsigned char)(c) <= _DS1E) || ((unsigned char)(c) >= _DS2S && (unsigned char)(c) <= _DS2E) || ((unsigned char)(c) >= _DS3S && (unsigned char)(c) <= _DS3E))
#else		/* Two 2nd byte areas */
#define IsDBCS2(c)	(((unsigned char)(c) >= _DS1S && (unsigned char)(c) <= _DS1E) || ((unsigned char)(c) >= _DS2S && (unsigned char)(c) <= _DS2E))
#endif
#else		/* SBCS configuration */
#define IsDBCS1(c)	0
#define IsDBCS2(c)	0
#endif /* _DF1S */
/* Definitions corresponds to multi partition */
#if _MULTI_PARTITION		/* Multiple partition configuration */
typedef struct _PARTITION {
	unsigned char pd;	/* Physical drive# */
	unsigned char pt;	/* Partition # (0-3) */
} PARTITION;
extern
const PARTITION Drives[];			/* Logical drive# to physical location conversion table */
#define LD2PD(drv) (Drives[drv].pd)	/* Get physical drive# */
#define LD2PT(drv) (Drives[drv].pt)	/* Get partition# */
#else						/* Single partition configuration */
#define LD2PD(drv) (drv)	/* Physical drive# is equal to the logical drive# */
#define LD2PT(drv) 0		/* Always mounts the 1st partition */
#endif
/* Definitions corresponds to multiple sector size */
#if _MAX_SS == 512 /* Single sector size */
#define	SS(fs)	512U
#elif _MAX_SS == 1024 || _MAX_SS == 2048 || _MAX_SS == 4096 /* Multiple sector size */
#define	SS(fs)	((fs)->s_size)
#else
#error Sector size must be 512, 1024, 2048 or 4096.
#endif
/* Type of file name on FatFs API */
#if _LFN_UNICODE && _USE_LFN
typedef unsigned short XCHAR;	/* Unicode */
#else
typedef char XCHAR;		/* SBCS, DBCS */
#endif
/* File system object structure */
typedef struct _FATFS_ {
	unsigned char	fs_type;	/* FAT sub type */
	unsigned char	drive;		/* Physical drive number */
	unsigned char	csize;		/* Number of sectors per cluster */
	unsigned char	n_fats;		/* Number of FAT copies */
	unsigned char	wflag;		/* win[] dirty flag (1:must be written back) */
	unsigned char	fsi_flag;	/* fsinfo dirty flag (1:must be written back) */
	unsigned short	id;		/* File system mount ID */
	unsigned short	n_rootdir;	/* Number of root directory entries (0 on FAT32) */
#if _FS_REENTRANT
	_SYNC_t	sobj;		/* Identifier of sync object */
#endif
#if _MAX_SS != 512
	unsigned short	s_size;		/* Sector size */
#endif
#if !_FS_READONLY
	unsigned long	last_clust;	/* Last allocated cluster */
	unsigned long	free_clust;	/* Number of free clusters */
	unsigned long	fsi_sector;	/* fsinfo sector */
#endif
#if _FS_RPATH
	unsigned long	cdir;		/* Current directory (0:root)*/
#endif
	unsigned long	sects_fat;	/* Sectors per fat */
	unsigned long	max_clust;	/* Maximum cluster# + 1. Number of clusters is max_clust - 2 */
	unsigned long	fatbase;	/* FAT start sector */
	unsigned long	dirbase;	/* Root directory start sector (Cluster# on FAT32) */
	unsigned long	database;	/* Data start sector */
	unsigned long	winsect;	/* Current sector appearing in the win[] */
	unsigned char	win[_MAX_SS];/* Disk access window for Directory/FAT */
} FATFS;
/* Directory object structure */
typedef struct _DIR_ {
	FATFS*	fs;			/* Pointer to the owner file system object */
	unsigned short	id;		/* Owner file system mount ID */
	unsigned short	index;	/* Current read/write index number */
	unsigned long	sclust;	/* Table start cluster (0:Static table) */
	unsigned long	clust;	/* Current cluster */
	unsigned long	sect;	/* Current sector */
	unsigned char*	dir;		/* Pointer to the current SFN entry in the win[] */
	unsigned char*	fn;		/* Pointer to the SFN (in/out) {file[8],ext[3],status[1]} */
#if _USE_LFN
	unsigned short*	lfn;	/* Pointer to the LFN working buffer */
	unsigned short	lfn_idx;	/* Last matched LFN index number (0xFFFF:No LFN) */
#endif
} DIR;
/* File object structure */
typedef struct _FIL_ {
	unsigned char	flag;	/* File status flags */
	unsigned char	csect;	/* Sector address in the cluster */
	unsigned long	fptr;		/* File R/W pointer */
	unsigned long	fsize;		/* File size */
	unsigned long	org_clust;	/* File start cluster */
	unsigned long	curr_clust;	/* Current cluster */
	unsigned long	dsect;		/* Current data sector */
#if !_FS_READONLY
	unsigned long	dir_sect;	/* Sector containing the directory entry */
	unsigned char*	dir_ptr;	/* Pointer to the directory entry in the window */
#endif
#if !_FS_TINY
	unsigned char	buf[_MAX_SS];/* File R/W buffer */
#endif
} FIL;
/* File status structure */
typedef struct _FILINFO_ {
	unsigned short	fdate;	/* Last modified date */
	unsigned short	ftime;	/* Last modified time */
	unsigned char	fattrib;	/* Attribute */
	char	fname[13];	/* Short file name (8.3 format) */
#if _USE_LFN
	XCHAR*	lfname;	/* Pointer to the LFN buffer */
	int 	lfsize;		/* Size of LFN buffer [chrs] */
#endif
} FILINFO;
/* File function return code (FRESULT) */
typedef enum {
	FR_OK = 0,		/* 0 */
	FR_DISK_ERR,		/* 1 */
	FR_INT_ERR,		/* 2 */
	FR_NOT_READY,		/* 3 */
	FR_NO_FILE,		/* 4 */
	FR_NO_PATH,		/* 5 */
	FR_INVALID_NAME,	/* 6 */
	FR_DENIED,		/* 7 */
	FR_EXIST,			/* 8 */
	FR_INVALID_OBJECT,	/* 9 */
	FR_WRITE_PROTECTED,	/* 10 */
	FR_INVALID_DRIVE,	/* 11 */
	FR_NOT_ENABLED,	/* 12 */
	FR_NO_FILESYSTEM,	/* 13 */
	FR_MKFS_ABORTED,	/* 14 */
	FR_TIMEOUT		/* 15 */
} FRESULT;
/* FatFs module application interface                           */
/* Mount/Unmount a logical drive */
FRESULT f_mount (unsigned char vol , FATFS* fs);
/* Open or create a file */
FRESULT f_open (FIL* fp, const XCHAR* path, unsigned char mode);
/* Read data from a file */
FRESULT f_read (FIL* fp, void* buff, unsigned int btr, unsigned int* br);
/* Write data to a file */
FRESULT f_write (FIL* fp, const void* buff, unsigned int btw, unsigned int* bw);
/* Move file pointer of a file object */
FRESULT f_lseek (FIL* fp, unsigned long ofs);
/* Close an open file object */
FRESULT f_close (FIL* fp);
/* Open a existing directory */
FRESULT f_opendir (DIR* dj, const XCHAR* path);
/* Read a directory item */
FRESULT f_readdir (DIR* dj, FILINFO* fno);
/* Get file status */
FRESULT f_stat (const XCHAR* path, FILINFO* fno);
/* Get number of free clusters on the drive */
FRESULT f_getfree (const XCHAR* path, unsigned long* nclst, FATFS** fatfs);
/* Truncate file */
FRESULT f_truncate (FIL* fp);
/* Flush cached data when writing file */
FRESULT f_sync (FIL* fp);
/* Delete an existing file or directory */
FRESULT f_unlink (const XCHAR* path);
/* Create a new directory */
FRESULT f_mkdir (const XCHAR* path);
/* Change attribute of a file or directory */
FRESULT f_chmod (const XCHAR* path, unsigned char value, unsigned char mask);
/* Change timestamp of a file or directory */
FRESULT f_utime (const XCHAR* path, const FILINFO* fno);
/* Rename/Move a file or directory */
FRESULT f_rename (const XCHAR* path_old, const XCHAR* path_new);
/* Change directory */
FRESULT f_chdir (const XCHAR* path);
/* Change drive */
FRESULT f_chdrive (unsigned char drv);
#if _USE_FORWARD
/* Forward data to a stream */
FRESULT f_forward (FIL* fp, unsigned int(*func)(const unsigned char*,unsigned int), unsigned int btr, unsigned int* bf);
#endif
#if _USE_MKFS
/* Create a file system on a drive */
FRESULT f_mkfs (unsigned char drv, unsigned char partition, unsigned short allocsize);
#endif
/* Pointer to a Real Time Clock function used for reading time */
extern void (*prtc_get_time) (unsigned char *hour, unsigned char *min, unsigned char *sec);
/* Pointer to a Real Time Clock function used for reading date */
extern void (*prtc_get_date) (unsigned char *date, unsigned char *month, unsigned *year);
/* User defined functions                                       */
/* Unicode - OEM code conversion */
#if _USE_LFN
unsigned short ff_convert (unsigned int, unsigned int);
unsigned short ff_wtoupper (unsigned int);
#endif
/* Sync functions */
#if _FS_REENTRANT
bool ff_cre_syncobj(unsigned char, _SYNC_t*);
bool ff_del_syncobj(_SYNC_t);
bool ff_req_grant(_SYNC_t);
void ff_rel_grant(_SYNC_t);
#endif
/* Flags and offset address                                     */
/* File access control and file status flags (FIL.flag) */
#define FA_READ			0x01
#define FA_OPEN_EXISTING	     0x00
#if _FS_READONLY == 0
#define FA_WRITE			0x02
#define FA_CREATE_NEW		0x04
#define FA_CREATE_ALWAYS	     0x08
#define FA_OPEN_ALWAYS		0x10
#define FA__WRITTEN			0x20
#define FA__DIRTY			0x40
#endif
#define FA__ERROR			0x80
/* FAT sub type (FATFS.fs_type) */
#define FS_FAT12	1
#define FS_FAT16	2
#define FS_FAT32	3
/* File attribute bits for directory entry */
#define AM_RDO	0x01	/* Read only */
#define AM_HID	0x02	/* Hidden */
#define AM_SYS	0x04	/* System */
#define AM_VOL	0x08	/* Volume label */
#define AM_LFN	0x0F	/* LFN entry */
#define AM_DIR	0x10	/* Directory */
#define AM_ARC	0x20	/* Archive */
#define AM_MASK 0x3F	/* Mask of defined bits */
/* FatFs refers the members in the FAT structures with byte offset instead
/ of structure member because there are incompatibility of the packing option
/ between various compilers. */
#define BS_jmpBoot			0
#define BS_OEMName			3
#define BPB_BytsPerSec		11
#define BPB_SecPerClus		13
#define BPB_RsvdSecCnt		14
#define BPB_NumFATs			16
#define BPB_RootEntCnt		17
#define BPB_TotSec16		19
#define BPB_Media			21
#define BPB_FATSz16			22
#define BPB_SecPerTrk		24
#define BPB_NumHeads		26
#define BPB_HiddSec			28
#define BPB_TotSec32		32
#define BS_55AA			510
#define BS_DrvNum			36
#define BS_BootSig			38
#define BS_VolID			39
#define BS_VolLab			43
#define BS_FilSysType		54
#define BPB_FATSz32			36
#define BPB_ExtFlags		40
#define BPB_FSVer			42
#define BPB_RootClus		44
#define BPB_FSInfo			48
#define BPB_BkBootSec		50
#define BS_DrvNum32			64
#define BS_BootSig32		66
#define BS_VolID32			67
#define BS_VolLab32			71
#define BS_FilSysType32		82
#define	FSI_LeadSig		0
#define	FSI_StrucSig		484
#define	FSI_Free_Count		488
#define	FSI_Nxt_Free		492
#define   MBR_Table			446
#define	DIR_Name			0
#define	DIR_Attr			11
#define	DIR_NTres			12
#define	DIR_CrtTime		14
#define	DIR_CrtDate		16
#define	DIR_FstClusHI		20
#define	DIR_WrtTime		22
#define	DIR_WrtDate		24
#define	DIR_FstClusLO		26
#define	DIR_FileSize		28
#define	LDIR_Ord			0
#define	LDIR_Attr			11
#define	LDIR_Type			12
#define	LDIR_Chksum		13
#define	LDIR_FstClusLO		26
/* Multi-byte word access macros  */
#define	LD_WORD(ptr)		(*(unsigned short*)(ptr))
#define	LD_DWORD(ptr)		(*(unsigned long*)(ptr))
#define	ST_WORD(ptr,val)	*(unsigned short*)(ptr)=(unsigned short)(val)
#define	ST_DWORD(ptr,val)	*(unsigned long*)(ptr)=(unsigned long)(val)
#pragma library ff.lib
#endif /* _FATFS */
See the enum
typedef enum {
	FR_OK = 0,		        /* 0 */
	FR_INT_ERR,		/* 2 */
	FR_NO_FILE,		/* 4 */
	FR_NO_PATH,		/* 5 */
	FR_DENIED,		/* 7 */
	FR_EXIST,			/* 8 */
	FR_TIMEOUT		/* 15 */
} FRESULT;
It is some FR initialize error. May be it is File Read.
Can you provide the link for chaN's library? Have you formatted the SD Card using FAT?
Well, thank for help:
I used uart0 to check and find out that the error stem from f_open function. And this is explain for error from:http://elm-chan.org/fsw/ff/en/rc.html
FR_INT_ERR
Assertion failed. An insanity is detected in the internal process. One of the following possibilities are suspected.
There is any error of the FAT structure on the volume.
Work area (file system object, file object or etc...) is broken by stack overflow or any other application. This is the reason in most case.
An FR_DISK_ERR has occured on the file object.
And this is link for chaN's library: http://elm-chan.org/fsw/ff/00index_e.html
I use sd card 1G and I formated it fat32 in computer.
The attached file is all code and the proteus file that i used. The proteus simulation is OK but when i load it into atmega128, i get the error:
COM1 OK Init OK
0:/file.txt
ERROR: FR_INT_ERR
  • SD CARD AT64.rar
