seeravi
Member level 1
When loading design compiler, i facing below error, solution plz.
Memory usage for J17 task 292 Mbytes -- main task 292 Mbytes.
Error: DDC internal read error in file '/tmp/dfrm-MUunLS/dcfarm-7988-nl.nl'. (DDC-4)
Memory usage for J18 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J19 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J20 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J21 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J22 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J23 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J24 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J25 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J26 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J27 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J28 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J29 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J30 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J31 task 292 Mbytes -- main task 292 Mbytes.
Memory usage for J32 task 292 Mbytes -- main task 292 Mbytes.
Processing 'must_bmu_top'
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent
Synopsys release, submit this stack trace and a test case that
reproduces the problem to the Synopsys Support Center by using
Enter A Call at https://solvnet.synopsys.com/EnterACall.
* For information about the latest software releases, go to the Synopsys
SolvNet Release Library at https://solvnet.synopsys.com/ReleaseLibrary.
* For information about required Operating System patches, go to
https://www.synopsys.com/support
Release = 'C-2009.06-SP4' Architecture = 'linux' Program = 'dc_shell'
Exec = '/tools/synopsys/V-2003.12/linux/syn/bin/common_shell_exec'
'238140140 238142010 238261675 238097861 156401667 156381239 156390893 152746892 152749042 151698076 237882095 239699626 239705706 239706544 237849712 237862273 237882095 239699626 239705706 239706544 237849712 237862273 237882095 239699626 239705706 239706544 237874685 237881358 148279468 148279613 148298159 148300381 148301676 134623195 134609050 8441315'
Regards,
Ravi.
Regards,
Ravi.
