ERROR -- Convergence problem in transient bias point calculation
aliraza54
Newbie level 2
Newbie level 2
hello, I have implemented the circuit shown in the image attached with this post. When i run the circuit it gives me and error i.e.
"ERROR -- Convergence problem in transient bias point calculation".
The simulation window shows these messages:
**** 04/18/15 12:56:13 ****** PSpice Lite (October 2012) ****** ID# 10813 ****
 ** Profile: "SCHEMATIC1-volam"  [ C:\Users\AliRaza\Desktop\Gates\VA\vola-pspicefiles\schematic1\volam.sim ]
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "volam.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Users\AliRaza\AppData\Roaming\SPB_16.6\cdssetup\OrCAD_PSpice/16.6.0/PSpice.ini file:
.lib "nomd.lib"
*Analysis directives:
.TRAN  0 100m 0 1u
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source VOLA
Q_Q1         N00123 N00210 N00134 QbreakN
Q_Q2         N00210 N00130 0 QbreakN
Q_Q3         N00123 N00134 N00130 QbreakN
R_R1         0 N00134  50k TC=0,0
R_R2         0 N00130  50 TC=0,0
V_V1         N00210 0 5Vdc
V_V2         N00123 0 5Vdc
R_R4         N01292 N01250  200k TC=0,0
R_R3         N01203 N01250  200k TC=0,0
V_V4         N01250 0 10Vdc
R_R5         N01299 0  1G TC=0,0
Q_Q4         N01292 N01203 N01299 QbreakN
**** RESUMING volam.cir ****
.END
 ****     BJT MODEL PARAMETERS
               QbreakN
               NPN
       LEVEL    1
          IS  100.000000E-18
          BF  100
          NF    1
          BR    1
          NR    1
         ISS    0
          RE    0
          RC    0
         CJE    0
         VJE     .75
         CJC    0
         VJC     .75
         MJC     .33
        XCJC    1
         CJS    0
         VJS     .75
          KF    0
          AF    1
          CN    2.42
           D     .87
  Last node voltages tried were:
 NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
(N00123)    4.2872 (N00130)    1.5484 (N00134)    2.9775 (N00210)    4.2872
(N01203)    8.5743 (N01250)    8.5743 (N01292)    8.5727 (N01299)    8.1035
  These supply currents failed to converge:
    I(V_V1)                   =   -10.00GA  \   -10.00GA
**** Interrupt ****
Are you joking? Obviously the schematic circuit doesn't belong to the netlist which has e.g. 4 transistors and three voltage sources.
