[SOLVED] error 148:variable " xxx" has already been initialized
dizgah
Member level 5
Member level 5
iran-8par
hi every body
im trying to port a avr c library to a stm32f103 arm cortex mcu,but i have this error(error 148:variable " xxx" has already been initialized)
im bewildered what it say ?
tnks
It's difficult to say with such little information. Please post or upload your code and state the compiler you are currently using.
Also a screen shot or posting of the line of code flagged by the error would be of help.
Most likely the issue stems from a conflict between your port code and the compiler header/code.
BigDog
Reactions: dizgah
    dizgah
Re: error 148:variable " xxx" has already been initialized
is 'xxx' declared as a const?
Brian.
yes its a const unsigned char
BigDog
thanks from you & betwixt,im try it on keil & iar (lite free versions) & all of them show same error
its a osama glcd library for avr im trying to port
i attached keil project (it have some other warning too , but at first im trying to solve errors step by step )
thanks again
hi every one
i founded my fault
i include font library 2 time
& it will be eliminate with using #ifndef or erease one of the includes
any way i will post other warning here & edit title (if it is not apposite with rules sir bigdogpue ;) )
my newer post wanished : ?
i find reason
i include font.h twice
& can do this with #ifndef or with ereasing one of the includes
then i will edite title & post my other problem related with porting this lib to keil stm32f103
  • GLCD.rar
The problem is most likely due to the fact some of your header files lack the proper preprocessor commands to prevent multiple inclusions of the header file.
Each time the header file font.h is included during the preprocessing phase of compilation, the array const char font[] is redefined, which in turn generates the error.
The generated error is an excellent example of why proper preprocessor commands must be incorporated into every header file.
Try something along the lines of:
#ifndef FONT_H
#define FONT_H
/* All the stuff you want in the header file goes between the #define and the #endif */
#endif
Current font.h:
const char font[]= {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //0/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //1/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //2/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //3/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //4/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //5/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //6/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //7/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //8/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //9/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //10/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //11/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //12/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //13/ -->  //Problem 2
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //14/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //15/ -->
0x20,0x20,0x28,0x28,0x68,0xB0,0x60,0x20, //16/ -->
0x20,0x20,0x28,0x2A,0x28,0x30,0x20,0x20, //17/ -->
0x00,0x80,0x80,0x44,0x32,0x24,0x20,0x20, //18/ -->
0x00,0x24,0x24,0x24,0x38,0x20,0x20,0x20, //19/ -->
0x20,0x20,0x20,0x20,0x24,0x2A,0x11,0x00, //20/ -->
0x20,0x20,0x20,0x24,0x2A,0x11,0x20,0x20, //21/ -->
0x30,0x20,0x20,0x20,0x24,0x2A,0x11,0x20, //22/ -->
0x20,0x20,0x30,0x20,0x30,0x28,0x28,0x18, //23/ -->
0x20,0x24,0x22,0x21,0x24,0x2A,0x11,0x00, //24/ -->
0x24,0x22,0x21,0x24,0x2A,0x11,0x20,0x20, //25/ -->
0x30,0x24,0x22,0x21,0x24,0x2A,0x11,0x20, //26/ -->
0x00,0x80,0x80,0x40,0x30,0x20,0x20,0x20, //27/ -->
0x20,0x20,0x20,0x60,0xA0,0x60,0x28,0x30, //28/ -->
0x20,0x20,0x20,0x60,0xB0,0x60,0x20,0x20, //29/ -->
0x00,0x30,0x28,0x60,0xA0,0x60,0x30,0x20, //30/ -->
0x00,0x04,0x06,0x1D,0x25,0x24,0x20,0x20, //31/ -->
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //32/ -->
0x00,0x00,0x4F,0x00,0x00,0x00,0x00,0x00, //33/ --> !
0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00, //34/ --> "
0x00,0x14,0x7F,0x14,0x7F,0x14,0x00,0x00, //35/ --> #
0x00,0x24,0x2A,0x7F,0x2A,0x12,0x00,0x00, //36/ --> $
0x00,0x23,0x13,0x08,0x64,0x62,0x00,0x00, //37/ --> %
0x00,0x36,0x49,0x55,0x22,0x40,0x00,0x00, //38/ --> &
0x00,0x00,0x05,0x03,0x00,0x00,0x00,0x00, //39/ --> '
0x00,0x1C,0x22,0x41,0x00,0x00,0x00,0x00, //40/ --> (
0x00,0x41,0x22,0x1C,0x00,0x00,0x00,0x00, //41/ --> )
0x00,0x14,0x08,0x3E,0x08,0x14,0x00,0x00, //42/ --> *
0x00,0x08,0x08,0x3E,0x08,0x08,0x00,0x00, //43/ --> +
0x00,0x00,0x28,0x18,0x00,0x00,0x00,0x00, //44/ --> ,
0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x00, //45/ --> -
0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00, //46/ --> .
0x00,0x20,0x10,0x08,0x04,0x02,0x00,0x00, //47/ --> /
0x00,0x3E,0x51,0x49,0x45,0x3E,0x00,0x00, //48/ --> 0
0x00,0x00,0x42,0x7F,0x40,0x00,0x00,0x00, //49/ --> 1
0x00,0x42,0x61,0x51,0x49,0x46,0x00,0x00, //50/ --> 2
0x00,0x21,0x41,0x45,0x4B,0x31,0x00,0x00, //51/ --> 3
0x00,0x18,0x14,0x12,0x7F,0x10,0x00,0x00, //52/ --> 4
0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00, //53/ --> 5
0x00,0x3C,0x4A,0x49,0x49,0x30,0x00,0x00, //54/ --> 6
0x00,0x01,0x71,0x09,0x05,0x03,0x00,0x00, //55/ --> 7
0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00, //56/ --> 8
0x00,0x06,0x49,0x49,0x29,0x1E,0x00,0x00, //57/ --> 9
0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00, //58/ --> :
0x00,0x00,0x56,0x36,0x00,0x00,0x00,0x00, //59/ --> ;
0x00,0x08,0x14,0x22,0x41,0x00,0x00,0x00, //60/ --> <
0x00,0x24,0x24,0x24,0x24,0x24,0x00,0x00, //61/ --> =
0x00,0x00,0x41,0x22,0x14,0x08,0x00,0x00, //62/ --> >
0x00,0x02,0x01,0x51,0x09,0x06,0x00,0x00, //63/ --> ?
0x00,0x32,0x49,0x79,0x41,0x3E,0x00,0x00, //64/ --> @
0x00,0x7E,0x11,0x11,0x11,0x7E,0x00,0x00, //65/ --> A
0x00,0x7F,0x49,0x49,0x49,0x36,0x00,0x00, //66/ --> B
0x00,0x3E,0x41,0x41,0x41,0x22,0x00,0x00, //67/ --> C
0x00,0x7F,0x41,0x41,0x22,0x1C,0x00,0x00, //68/ --> D
0x00,0x7F,0x49,0x49,0x49,0x41,0x00,0x00, //69/ --> E
0x00,0x7F,0x09,0x09,0x09,0x01,0x00,0x00, //70/ --> F
0x00,0x3E,0x41,0x49,0x49,0x3A,0x00,0x00, //71/ --> G
0x00,0x7F,0x08,0x08,0x08,0x7F,0x00,0x00, //72/ --> H
0x00,0x00,0x41,0x7F,0x41,0x00,0x00,0x00, //73/ --> I
0x00,0x20,0x40,0x41,0x3F,0x01,0x00,0x00, //74/ --> J
0x00,0x7F,0x08,0x14,0x22,0x41,0x00,0x00, //75/ --> K
0x00,0x7F,0x40,0x40,0x40,0x40,0x00,0x00, //76/ --> L
0x00,0x7F,0x02,0x0C,0x02,0x7F,0x00,0x00, //77/ --> M
0x00,0x7F,0x04,0x08,0x10,0x7F,0x00,0x00, //78/ --> N
0x00,0x3E,0x41,0x41,0x41,0x3E,0x00,0x00, //79/ --> O
0x00,0x7F,0x09,0x09,0x09,0x06,0x00,0x00, //80/ --> P
0x3E,0x41,0x51,0x21,0x5E,0x00,0x00,0x00, //81/ --> Q
0x00,0x7F,0x09,0x19,0x29,0x46,0x00,0x00, //82/ --> R
0x00,0x46,0x49,0x49,0x49,0x31,0x00,0x00, //83/ --> S
0x00,0x01,0x01,0x7F,0x01,0x01,0x00,0x00, //84/ --> T
0x00,0x3F,0x40,0x40,0x40,0x3F,0x00,0x00, //85/ --> U
0x00,0x1F,0x20,0x40,0x20,0x1F,0x00,0x00, //86/ --> V
0x00,0x3F,0x40,0x60,0x40,0x3F,0x00,0x00, //87/ --> W
0x00,0x63,0x14,0x08,0x14,0x63,0x00,0x00, //88/ --> X
0x00,0x07,0x08,0x70,0x08,0x07,0x00,0x00, //89/ --> Y
0x00,0x61,0x51,0x49,0x45,0x43,0x00,0x00, //90/ --> Z
0x00,0x7F,0x41,0x41,0x00,0x00,0x00,0x00, //91/ --> [
0x00,0x15,0x16,0x7C,0x16,0x15,0x00,0x00, //92/ --> '\'
0x00,0x41,0x41,0x7F,0x00,0x00,0x00,0x00, //93/ --> ]
0x00,0x04,0x02,0x01,0x02,0x04,0x00,0x00, //94/ --> ^
0x00,0x40,0x40,0x40,0x40,0x40,0x00,0x00, //95/ --> _
0x00,0x01,0x02,0x04,0x00,0x00,0x00,0x00, //96/ --> `
0x00,0x20,0x54,0x54,0x54,0x78,0x00,0x00, //97/ --> a
0x00,0x7F,0x44,0x44,0x44,0x38,0x00,0x00, //98/ --> b
0x00,0x38,0x44,0x44,0x44,0x00,0x00,0x00, //99/ --> c
0x00,0x38,0x44,0x44,0x48,0x7F,0x00,0x00, //100/ --> d
0x00,0x38,0x54,0x54,0x54,0x18,0x00,0x00, //101/ --> e
0x00,0x10,0x7E,0x11,0x01,0x02,0x00,0x00, //102/ --> f
0x00,0x0C,0x52,0x52,0x52,0x3E,0x00,0x00, //103/ --> g
0x00,0x7F,0x08,0x04,0x04,0x78,0x00,0x00, //104/ --> h
0x00,0x00,0x44,0x7D,0x40,0x00,0x00,0x00, //105/ --> i
0x00,0x20,0x40,0x40,0x3D,0x00,0x00,0x00, //106/ --> j
0x00,0x7F,0x10,0x28,0x44,0x00,0x00,0x00, //107/ --> k
0x00,0x00,0x41,0x7F,0x40,0x00,0x00,0x00, //108/ --> l
0x00,0x7C,0x04,0x18,0x04,0x78,0x00,0x00, //109/ --> m
0x00,0x7C,0x08,0x04,0x04,0x78,0x00,0x00, //110/ --> n
0x00,0x38,0x44,0x44,0x44,0x38,0x00,0x00, //111/ --> o
0x00,0x7C,0x14,0x14,0x14,0x08,0x00,0x00, //112/ --> p
0x00,0x08,0x14,0x14,0x18,0x7C,0x00,0x00, //113/ --> q
0x00,0x7C,0x08,0x04,0x04,0x08,0x00,0x00, //114/ --> r
0x00,0x48,0x54,0x54,0x54,0x20,0x00,0x00, //115/ --> s
0x00,0x04,0x3F,0x44,0x40,0x20,0x00,0x00, //116/ --> t
0x00,0x3C,0x40,0x40,0x20,0x7C,0x00,0x00, //117/ --> u
0x00,0x1C,0x20,0x40,0x20,0x1C,0x00,0x00, //118/ --> v
0x00,0x1E,0x20,0x10,0x20,0x1E,0x00,0x00, //119/ --> w
0x00,0x22,0x14,0x08,0x14,0x22,0x00,0x00, //120/ --> x
0x00,0x06,0x48,0x48,0x48,0x3E,0x00,0x00, //121/ --> y
0x00,0x44,0x64,0x54,0x4C,0x44,0x00,0x00, //122/ --> z
0x00,0x08,0x36,0x41,0x00,0x00,0x00,0x00, //123/ --> {
0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00, //124/ --> |
0x00,0x41,0x36,0x08,0x00,0x00,0x00,0x00, //125/ --> }
0x00,0x08,0x08,0x2A,0x1C,0x08,0x00,0x00, //126/ --> ~
0x00,0x08,0x1C,0x2A,0x08,0x08,0x00,0x00, //127/ -->
0x00,0x3C,0x42,0x41,0x42,0x3C,0x00,0x00, //128/ --> €
0x00,0x30,0x28,0x60,0xA0,0x60,0x28,0x30, //129/ --> Ù¾
0x20,0x20,0x20,0x20,0xA0,0x20,0x28,0x30, //130/ --> ‚
0x20,0x20,0x20,0x20,0xB0,0x20,0x20,0x20, //131/ --> Æ’
0x00,0x30,0x28,0x20,0xA0,0x20,0x30,0x20, //132/ --> „
0x20,0x20,0x20,0x22,0x20,0x22,0x28,0x30, //133/ --> …
0x20,0x20,0x20,0x22,0x30,0x22,0x20,0x20, //134/ --> â€*
0x00,0x30,0x28,0x22,0x20,0x22,0x30,0x20, //135/ --> ‡
0x20,0x20,0x20,0x22,0x21,0x22,0x28,0x30, //136/ --> ˆ
0x20,0x20,0x20,0x22,0x31,0x22,0x20,0x20, //137/ --> ‰
0x00,0x30,0x28,0x22,0x21,0x22,0x30,0x20, //138/ --> Ù¹
0x20,0x20,0x28,0x28,0x28,0xB0,0x20,0x20, //139/ --> ‹
0x20,0x20,0x28,0x28,0x28,0x30,0x20,0x20, //140/ --> Å’
0x00,0xC0,0xA8,0x28,0x68,0xB0,0x60,0x20, //141/ --> Ú†
0x00,0x00,0x80,0x80,0x44,0x32,0x04,0x00, //142/ --> Ú˜
0x00,0x24,0x25,0x24,0x38,0x20,0x20,0x20, //143/ --> Úˆ
0x30,0x24,0x22,0x21,0x24,0x2A,0x11,0x00, //144/ --> Ú¯
0x00,0x80,0x80,0x40,0x34,0x20,0x20,0x20, //145/ --> ‘
0x20,0x20,0x20,0x38,0x20,0x38,0x20,0x18, //146/ --> ’
0x20,0x20,0x38,0x20,0x38,0x20,0x38,0x20, //147/ --> “
0x60,0x80,0x80,0x78,0x20,0x38,0x20,0x18, //148/ --> ”
0x20,0x20,0x20,0x38,0x22,0x39,0x22,0x18, //149/ --> •
0x20,0x20,0x38,0x22,0x39,0x22,0x38,0x20, //150/ --> –
0x60,0x80,0x80,0x78,0x22,0x39,0x22,0x18, //151/ --> —
0x30,0x20,0x20,0x20,0x24,0x2A,0x11,0x00, //152/ --> Ú©
0x20,0x30,0x20,0x30,0x28,0x28,0x38,0x20, //153/ --> â„¢
0x60,0x80,0x80,0x60,0x30,0x28,0x28,0x38, //154/ --> Ú‘
0x20,0x20,0x30,0x20,0x30,0x28,0x2A,0x18, //155/ --> ›
0x20,0x30,0x20,0x30,0x28,0x2A,0x38,0x20, //156/ --> Å“
0x60,0x80,0x80,0x60,0x30,0x28,0x2A,0x38, //157/ --> ‌
0x20,0x20,0x3E,0x30,0x28,0x28,0x38,0x20, //158/ --> ‍
0x20,0x20,0x3E,0x30,0x28,0x2A,0x38,0x20, //159/ --> Úº
0x20,0x20,0x20,0x20,0x30,0x28,0x28,0x00, //160/ -->
0x20,0x20,0x20,0x30,0x28,0x28,0x20,0x20, //161/ --> ،
0x00,0x40,0xA0,0xB0,0x28,0x28,0x20,0x20, //162/ --> ¢
0x20,0x20,0x20,0x20,0x30,0x28,0x2A,0x00, //163/ --> £
0x20,0x20,0x20,0x30,0x28,0x2A,0x20,0x20, //164/ --> ¤
0x00,0x40,0xA0,0xB0,0x28,0x2A,0x20,0x20, //165/ --> ¥
0x20,0x20,0x20,0x20,0x30,0x28,0x2A,0x30, //166/ --> ¦
0x20,0x20,0x30,0x28,0x2A,0x30,0x20,0x20, //167/ --> §
0x00,0x18,0x20,0x20,0x30,0x28,0x2A,0x30, //168/ --> ¨
0x20,0x20,0x20,0x20,0x30,0x2A,0x28,0x32, //169/ --> ©
0x20,0x20,0x30,0x2A,0x28,0x32,0x20,0x20, //170/ --> Ú¾
0x60,0x80,0x80,0xB2,0xA8,0x7A,0x20,0x20, //171/ --> «
0x22,0x25,0x25,0x25,0x25,0x25,0x25,0x19, //172/ --> ¬
0x20,0x20,0x20,0x1C,0x22,0x21,0x20,0x20, //173/ --> Â*
0x30,0x28,0x2C,0x2A,0x20,0x3F,0x20,0x20, //174/ --> ®
0x20,0x20,0x20,0x20,0x20,0x20,0x1F,0x00, //175/ --> ¯
0x20,0x20,0x20,0x20,0x1F,0x20,0x20,0x20, //176/ --> °
0x00,0x30,0x40,0x40,0x3F,0x20,0x20,0x20, //177/ --> ±
0x20,0x20,0x20,0x20,0x30,0x48,0x48,0x30, //178/ --> ²
0x20,0x20,0x30,0x48,0x48,0x30,0x20,0x20, //179/ --> ³
0x80,0x40,0x30,0x48,0x48,0x30,0x20,0x20, //180/ --> ´
0x20,0x20,0x20,0x20,0x22,0x20,0x18,0x00, //181/ --> µ
0x20,0x20,0x20,0x20,0x1A,0x20,0x20,0x20, //182/ --> ¶
0x30,0x40,0x44,0x40,0x30,0x20,0x20,0x20, //183/ --> ·
0x20,0x20,0x20,0x30,0x28,0x3A,0x2C,0x18, //184/ --> ¸
0x20,0x20,0x30,0x28,0x3A,0x2C,0x38,0x20, //185/ --> ¹
0x00,0x18,0x14,0x14,0x18,0x20,0x20,0x20, //186/ --> Ø›
0x00,0x21,0x22,0x24,0x28,0x10,0x0F,0x00, //187/ --> »
0x00,0xB0,0xA8,0x78,0x20,0x20,0x20,0x20, //188/ --> ¼
0x20,0x20,0x20,0xA0,0x20,0xA0,0x28,0x30, //189/ --> ½
0x20,0x20,0x20,0xA0,0x30,0xA0,0x20,0x20, //190/ --> ¾
0x00,0x60,0x80,0x80,0xA0,0x50,0x10,0x20, //191/ --> ØŸ
0x00,0x1E,0x20,0x20,0x20,0x20,0x20,0x20, //192/ --> ہ
0x00,0x20,0x30,0x28,0x28,0x20,0x00,0x00, //193/ --> Ø¡
0x00,0x04,0x02,0x02,0x3A,0x02,0x02,0x01, //194/ --> آ
0x00,0x00,0x04,0x06,0x3D,0x05,0x04,0x00, //195/ --> أ
0x00,0x00,0x04,0xB6,0xAD,0x7D,0x04,0x00, //196/ --> ؤ
0x00,0x00,0x80,0xC0,0xBF,0xA0,0x80,0x00, //197/ --> إ
0x04,0x66,0x85,0x95,0xA8,0xA8,0x48,0x00, //198/ --> ئ
0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00, //199/ --> ا
0x00,0x30,0x28,0x20,0xA0,0x20,0x28,0x30, //200/ --> ب
0x00,0x00,0x30,0x2A,0x28,0x32,0x00,0x00, //201/ --> Ø©
0x00,0x30,0x28,0x22,0x20,0x22,0x28,0x30, //202/ --> ت
0x00,0x30,0x28,0x22,0x21,0x22,0x28,0x30, //203/ --> Ø«
0x00,0xC0,0xA8,0xA8,0x28,0xB0,0x20,0x20, //204/ --> ج
0x00,0xC0,0xA8,0xA8,0xA8,0x30,0x20,0x20, //205/ --> Ø*
0x00,0xC0,0xA8,0xAA,0x28,0x30,0x20,0x20, //206/ --> Ø®
0x00,0x00,0x24,0x24,0x24,0x38,0x00,0x00, //207/ --> د
0x00,0x00,0x24,0x25,0x24,0x38,0x00,0x00, //208/ --> Ø°
0x00,0x80,0x80,0x40,0x30,0x00,0x00,0x00, //209/ --> ر
0x00,0x00,0x80,0x80,0x40,0x34,0x00,0x00, //210/ --> ز
0x60,0x80,0x80,0x78,0x20,0x38,0x20,0x18, //211/ --> س
0x60,0x80,0x80,0x78,0x22,0x39,0x22,0x18, //212/ --> Ø´
0x60,0x80,0x80,0x60,0x30,0x28,0x28,0x18, //213/ --> ص
0x60,0x80,0x80,0x60,0x30,0x28,0x2A,0x18, //214/ --> ض
0x00,0x22,0x14,0x08,0x14,0x22,0x00,0x00, //215/ --> ×
0x20,0x20,0x3E,0x30,0x28,0x28,0x18,0x00, //216/ --> Ø·
0x20,0x20,0x3E,0x30,0x28,0x2A,0x18,0x00, //217/ --> ظ
0x00,0x00,0x40,0xA0,0xB0,0x28,0x28,0x00, //218/ --> ع
0x00,0x00,0x40,0xA0,0xB0,0x2A,0x28,0x00, //219/ --> غ
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20, //220/ --> Ù€
0x00,0x18,0x20,0x20,0x30,0x28,0x2A,0x30, //221/ --> ف
0x00,0x60,0x80,0x80,0xB2,0xA8,0x7A,0x00, //222/ --> Ù‚
0x00,0x30,0x28,0x2C,0x2A,0x20,0x3F,0x00, //223/ --> Ùƒ
0x00,0x40,0xA9,0xAA,0xA8,0xF0,0x00,0x00, //224/ --> Ã*
0x00,0x00,0x60,0x80,0x80,0x7E,0x00,0x00, //225/ --> Ù„
0x00,0x40,0xAA,0xA9,0xAA,0xF0,0x00,0x00, //226/ --> â
0x00,0x00,0xC0,0x20,0x30,0x28,0x28,0x30, //227/ --> Ù…
0x00,0x00,0x60,0x80,0x88,0x80,0x60,0x00, //228/ --> Ù†
0x00,0x00,0x30,0x28,0x28,0x30,0x00,0x00, //229/ --> Ù‡
0x00,0x00,0x00,0xB0,0xA8,0x78,0x00,0x00, //230/ --> Ùˆ
0x04,0x26,0x25,0x25,0x28,0x10,0x0F,0x00, //231/ --> ç
0x04,0x22,0x22,0x26,0x29,0x10,0x0F,0x00, //232/ --> è
0x00,0x21,0x22,0x24,0xA8,0xD0,0xAF,0xA0, //233/ --> é
0x00,0x70,0xAA,0xA9,0xAA,0x30,0x00,0x00, //234/ --> ê
0x00,0x70,0xAA,0xA8,0xAA,0x30,0x00,0x00, //235/ --> ë
0x00,0x30,0x40,0x40,0x50,0x28,0x08,0x00, //236/ --> Ù‰
0x00,0x30,0xC0,0x40,0xD0,0x28,0x08,0x00, //237/ --> ÙŠ
0x00,0x00,0x02,0x79,0x02,0x00,0x00,0x00, //238/ --> î
0x00,0x00,0x02,0x78,0x02,0x00,0x00,0x00, //239/ --> ï
0x00,0x00,0x00,0x00,0x00,0x05,0x05,0x05, //240/ --> Ù‹
0x00,0x00,0x00,0x04,0x03,0x0B,0x06,0x06, //241/ --> ٌ
0xA0,0xA0,0xA0,0x00,0x00,0x00,0x00,0x00, //242/ --> ٍ
0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00, //243/ --> ÙŽ
0x00,0x21,0x22,0x24,0x28,0x10,0x2F,0x20, //244/ --> ô
0x00,0x00,0x00,0x00,0x00,0x04,0x03,0x03, //245/ --> ُ
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00, //246/ --> ِ
0x00,0x00,0x10,0x10,0x54,0x10,0x10,0x00, //247/ --> ÷
0x00,0x00,0x02,0x04,0x02,0x04,0x02,0x00, //248/ --> Ù‘
0x20,0x24,0x26,0x25,0x25,0x20,0x28,0x30, //249/ --> ù
0x20,0x24,0x26,0x25,0x35,0x20,0x20,0x20, //250/ --> Ù’
0x08,0x6C,0x8A,0x8A,0xA0,0x50,0x10,0x20, //251/ --> û
0x04,0xB6,0xAD,0x7D,0x24,0x20,0x20,0x20, //252/ --> ü
0x00,0x19,0x14,0x15,0x18,0x20,0x20,0x20, //253/ --> ‎
0x04,0x02,0x02,0x1A,0x22,0x22,0x21,0x20, //254/ --> ‏
0x00,0x40,0x60,0x50,0x48,0x50,0x40,0x40 //255/ --> Û’
const char font_map[62][6]= {
{193,193,193,193,0,0},
{194,194,254,254,1,0},
{195,195,31,31,1,0},
{196,196,252,252,1,0},
{197,197,197,197,1,1},
{198,189,191,190,1,1},
{199,199,192,192,1,0},
{200,130,132,131,1,1},
{201,201,253,253,1,0},
{202,133,135,134,1,1},
{203,136,138,137,1,1},
{204,139,204,139,1,1},
{205,140,205,140,1,1},
{206,17,206,17,1,1},
{207,207,19,19,1,0},
{208,208,143,143,1,0},
{209,209,27,27,1,0},
{210,210,145,145,1,0},
{211,146,148,147,1,1},
{212,149,151,150,1,1},
{213,23,154,153,1,1},
{214,155,157,156,1,1},
{215,215,215,215,0,0},
{216,216,158,158,1,1},
{217,217,159,159,1,1},
{218,160,162,161,1,1},
{219,163,165,164,1,1},
{220,220,220,220,0,0},
{221,166,168,167,1,1},
{222,169,171,170,1,1},
{223,172,174,173,1,1},
{224,224,224,224,0,0},
{225,175,177,176,1,1},
{226,226,226,226,0,0},
{227,178,180,179,1,1},
{228,181,183,182,1,1},
{229,184,186,185,1,1},
{230,230,188,188,1,0},
{231,231,231,231,0,0},
{232,232,232,232,0,0},
{233,233,233,233,0,0},
{234,234,234,234,0,0},
{235,235,235,235,0,0},
{236,189,191,190,1,1},
{237,189,191,190,1,1},
{238,238,238,238,0,0},
{239,239,239,239,0,0},
{240,240,240,240,0,0},
{241,241,241,241,0,0},
{242,242,242,242,0,0},
{243,243,243,243,0,0},
{245,245,245,245,0,0},
{246,246,246,246,0,0},
{247,247,247,247,0,0},
{248,248,248,248,0,0},
{251,249,251,250,1,1},
{187,187,244,244,1,0},
{129,28,30,29,1,1},
{144,24,26,25,1,1},
{152,20,22,21,1,1},
{142,142,18,18,1,0},
{141,16,141,16,1,1}
Modified font.h:
[COLOR="#FF0000"]#ifndef FONT_H
#define FONT_H
[/COLOR]
0x20,0x20,0x20,0x22,0x30,0x22,0x20,0x20, //134/ --> †
{129,28,30,29,1,1},
{144,24,26,25,1,1},
{152,20,22,21,1,1},
{141,16,141,16,1,1}
[COLOR="#FF0000"]#endif[/COLOR]
The above technique should be done for each and every header file, replacing the FONT_H label with a unique label for that particular header file.
BigDog
Reactions: dizgah
    dizgah
