shahrilmajid
Can anyone help me? I am trying to use concurrent statements in this code. Is there anything wrong with ";" that I use in the code ?
Would you mind to post .vhd text instead of a screenshot, so we can check the actual code?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity whenelse is
port (in_A, in_B : in std_logic_vector (7 downto 0);
opcode : in std_logic_vector (1 downto 0);
out_y : out std_logic_vector (7 downto 0);
carry : out std_logic);
end whenelse;
architecture beh of whenelse is
signal tmp : std_logic_vector(8 downto 0);
begin
process (opcode)
begin
--start code
tmp <= ("0" & in_A) + ("0" & in_B) when opcode = "00" else
("0" & in_A) - ("0" & in_B) when opcode = "01" else
("0" & in_A) and ("0" & in_B) when opcode = "10" else
("0" & in_A) or ("0" & in_B) when opcode = "11" ;
end process;
out_y <= tmp (7 downto 0);
carry <= tmp (8);
end beh;
Is it possible for me to use concurrent assignment with "when" "else" statemen as in https://insights.sigasi.com/tech/signal-assignments-vhdl-withselect-whenelse-and-case/Would you mind to post .vhd text instead of a screenshot, so we can check the actual code?
Error is to use conditional assignment (to be used in concurrent code) in a process (sequential code). Use a case construct or "if elsif else" instead.
begin
-- process (opcode)
-- begin
--start code
-- end process;
carry <= tmp (8);
end beh;
Thank you. I learned something today from you today.Or simply remove the unneccessary process:
Code:architecture beh of whenelse is signal tmp : std_logic_vector(8 downto 0); begin -- process (opcode) -- begin --start code tmp <= ("0" & in_A) + ("0" & in_B) when opcode = "00" else ("0" & in_A) - ("0" & in_B) when opcode = "01" else ("0" & in_A) and ("0" & in_B) when opcode = "10" else ("0" & in_A) or ("0" & in_B) when opcode = "11" ; -- end process; out_y <= tmp (7 downto 0); carry <= tmp (8); end beh;
Thanks for mentioning. It's not yet supported by Quartus in VHDL2008 setting, at least until V20.1.When-else syntax is only valid inside a process from VHDL 2008 onwards.
