Environment Variables
diemilio
Full Member level 6
Framingham, MA
Hi everyone. I'm trying to understand some of the Environment variables used to setup the Design Compiler (by synopsys) BUT I CANT!!! Does anyone know where can I find info regarding these variables???
Thanks for your help,
diemilio
have you looked at the sample designs and readme texts
within the apps install folders
usualy applications installs yields heeps of sample designs
try that
Enironmental mainly are the parameters that are not part of the design but influence the design
PVT ,WLM etc
Did you mean you did not know how to set variables such as 'link_library' ?
They are fully explained in Synopsys's documents.
If you did not understand variables such as PATH ,you should learn a bit more about Unix/Linux.
No. What I mean is that I haven't been able to find info regarding variables like
VCS_ARCH_OVERRIDE
SNPSLMD
SYNOPSYS_SIM
etc...
I have been able to understand a lot of the variables' meanings with examples I found on the web, but there are some (like the ones listed above) that I haven't been able to understand.
I just want to know if there's any website or document where I can find an explanation for the SYNOPSYS' ENV Variables.
Thanks,
diemilio
