I am using Encounter RC compiler to synthesize my verilog/vhdl files into gate-level netlists, using a standard cell library.
However, the logic synthesis process only creates a synthesized .v file (output file)
Is it possible to generate a .vhd synthesized file using RTL compiler?
this is an analog IC design forum, why post here? Most synthesizers generate (structural) verilog since most place and route tool only accept verilog, you can always use import>verilog to generate a schematic to review the result
Sorry for posting in the wrong forum. How do i move it to the correct forum?
By the way, the problem arises when I need to simulate the synthesized design (with gate delays).
I have a vhdl design and testbench (vhdl). And since after synthesis i get a verilog file, i cannot simulate that file using my vhdl testbench.
