short a=0;
#INT_EXT
void EXT_isr(void)
if(a==1)//check if interrupt0 is enabled
output_toggle(PIN_C2);//toggle an led according to the pulses
#INT_EXT1
void EXT1_isr(void)
a=1;
if(a==1)
output_toggle(PIN_C1);//toggle an led whenever switch is ON
ext_int_edge(0,L_TO_H);//interrupt0 generate at low to high transaction
enable_interrupts(INT_EXT);
void main()
ext_int_edge(1,H_TO_L);//interrupt1 generate at high to low transaction
enable_interrupts(INT_EXT1);//interrupt1 is enable here
enable_interrupts(GLOBAL);
while(1)
if(input(PIN_B1))//check if switch is OFF
a=0;//
disable_interrupts(INT_EXT);//disable interrupt0
output_toggle(PIN_C0);//toggle an LED continuously
delay_ms(500);
