electronZ
Member level 2
Hello all,
Long time since I have been here. Feels good to post again :-D
I want to sketch a design of a SMPS for audio applications. It has to operate with universal input and it outputs 400 Wrms @ +/- 60 V.
Please see the block diagram below.
The transformer in the PFC Converter will provide the safety isolation. I am trying to find out what the minimum creepage and clearance distances between primary and secondary side of the transformer.
I have been reading around in 60950-1 2006, and here is what I got:
1. Pollution degree 2
2. Reinforced insulation
3. Overvoltage Category II: 2500 Vpk @ AC Mains Supply 300 Vrms (Table 2J)
4. Minimum clearance for insulation in primary circuits and between primary and secondary circuits/side of the transformer is 4 mm for reinforced insulation at peak voltage of 420 V (Table 2K)
5. Minimum creepage distance on Printed boards, material Group IIIb, Basic insulation 0.75 mm and for Reinforced insulation it is 2x0.75 mm having RMS working voltage of 320. But since it is less than the clearance distance, the value of minimum CLEARANCE shall be applied as the minimum creepage distance (Section 2.10.4.3 Minimum creepage distances)
How does the above sound? Am I missing somthing?
