[SOLVED] EM Simulation of GSG Pads
Puppet123
Full Member level 6
Hello,
I am designing GSG pads for probing RFIC/MMIC and want to simulate this in Keysight Momentum.
What type of port type do I use - point ? Do I place it in the middle of the pad where I will probe? The edge of the pad? Is it an edge type port ?
Thanks.
Pin/port position determines the reference planes, so I place it where the probe tip touches down.
Hello Volker@Muelhaus,
Thank you for your message.
In that screenshot you sent - is the signal pad on the top metal and the gnd pads are on all metal layers via-ed down to the "blue" layer - which I assume is ground ?
Is this correct ?
Thank you.
Yes, the blue layer is Metal1 and used as a ground plane in this transmission line case. In other cases (e.g. inductors) there is no ground plane, and the vias are connected down to the substrate.
The GND pads you are using in that set up - they are going from Top metal through to all the metals down to the gnd metal layers - so all metal layers on top of one another and then down to metal 1 - with many vias ?
Thank you.
Yes, to make the via connection you also need the intermediate layers.
What layer are your port pins on - are they all on top metal ?
Thank you.
Hello Volker@Meulhaus,
Here is a copy of my simulation in Momentum.
Wondering if you can comment on it.
I have 3 three pads, two on sides, on top metal via-ed all the way down to ground plane in blue with vias - flattened to speed up simulation.
Middle pad, signal pad, with top metal only.
Middle pad, connect to microstrip transmission line with M9 signal layer and M1 ground, same as blue ground plane.
Ports all on top metal - set up in momentum - signal pad port is positive, two ground pads are negative.
What is wrong - the results are nonsense.
Thank you.
Yes, pins on top metal. What you describe sounds correct to me. No idea what goes wrong in your case. Have you checked current density view to see the current path?
No, its working fine, my mistake.
Thank you.
