Electrical Lenght of Microstrip Transmission Lines
denizduran
Member level 2
I am building a conventional feed network using lambda/4 transformers to feed my patch antenna array. Sometimes, I need to increase the length of my transmission line to fit everything. For example, I have a 50 ohm trl as a starting point, when I split that trl I have two 100 ohm trl branches but I need those branches to be longer, so I increase their length by half a wavelength. Should I be designing all the other trl half a wavelength longer?
FvM
Super Moderator
Staff member
Bochum, Germany
Not clear what you are exactly trying to achieve. Without specified source and load impedance, we can't recognize a transformer.
denizduran
Member level 2
The transformer isn't the point here. All I want to know is; if I change the electric length of one transmission line (like the 100 ohm trl) do I have to change the electric length of all the other trl's in the feed?
BigBoss
Advanced Member level 5
Turkiye
I didn't understand what you exactly mean but if you change the Length of any Transmission Line which is Loaded by Arbitrary Impedance, the Impedance that is seen at L=z point will also be changed.
That's why it changes depending which Impedance you desire at L=z point.
But you query is not so clear.
denizduran
Member level 2
I am just trying to design a feed system. I need to make some of my lines longer for the transmission lines not to intersect. If I double the electric length for one tranmission line (from 180 to 360 degrees) do I have to change the dielectric length for other transmission lines in the feed?
BigBoss
Turkiye
If the Feeding Transmission Line has 50 Ohm Characteristic Impedance, no matter its length is. But don't forget that no Transmission Line has 50 Ohm "Pure" Characteristic Impedance so changing its length may change the Driving Point Impedance too. So some tuning may have necessity ( may be not, depends on how it will be tolerated )
LaTeX Commands Quick-Menu:
