eight analog input working with pic18f4550
ptte
eight analog input
Hi,,,
am working with pic18f4550 to read eight analog inputs parallely from(AN0-AN7)
i tried some code but did't get read all eight pins...
can anyone help me with similar kind of code or any examples...
thanks,
eight analog input
post your code
Re: eight analog input
for(j=0; j<=1; j++){
if(TRISAbits.TRISA0==1)
ReadPOT();
temp = ReadADC();
itoa(temp/2,adc_buffer1);
putsUSBUSART(adc_buffer1);
if(TRISAbits.TRISA1==1)
ReadPOT();
temp = ReadADC();
itoa(temp/2,adc_buffer2);
putsUSBUSART(adc_buffer2);
this is for two channels
I'm not sure which compiler you are using but I can't see why you are checking the TRIS bits before talking a reading. Can you explain.
Brian.
eight analog input
MCC18 only am using...
if pin0 and pin1 are 1 means it should read analog value...
I don't use MCC18 but I can tell you the TRIS bits have very little to do with selecting analog inputs. The TRIS bits set the port bit direction, 0 = output, 1 = input. You set them as you wish but they do not change by themselves so I can't see why you are checking them in your program.
I think what you should do is set the bits in the ADC part of the PIC so the pins are analog inputs then select the one you want to read, then take the measurement.
For the second reading, select the next input and then read the value.
