4 feeds is use to obtain good axial ratio, phase center stability, rad. pattern in hemisphere, because it is GNSS antenna (f1~1230 MHz, f2=1560 MHz). Below the power and efficiency vs frequency is presented.
1 port is excited:
4 ports are excited:
«power outgoing all ports» contains reflected and transmited to other port power.
An efficiency calculation takes «power outgoing all ports» into account
Calculation was performed by combining 3d farfield, but when real devider was used in model, the efficiency results have been the same.
