powersys
Advanced Member level 1
Sorrie... you didn't sound arrogant at all to me... Pls don't feel offended... If you did, here's my apologies... you know, my english is away off... Honestly, I really appreciate every single idea you share with us here... Thanks.max0412 said:Sorry if I came off as arrogant. That wasn’t my intent.
Very similar to my case... I will try your approach... really thanks.max0412 said:I was the same as you my efficiency measurements were way off. For example some people in my class were getting 98% efficiency using my instructor’s procedure. This isn’t likely to happen particularly by a bunch of inexperienced students (Dixon, Middelbrock, Cuk maybe). So I did some more research reviewed my calculation. Noting the input current waveform and came to the conclusion that that is the problem. I want the average value of that wave form. So how do I get it? There is no instrument in the lab that will give it to me directly so I came up with the method above. Using that method brought my efficiency to within 3 to 5 % of calculated. Oddly enough that is the way my instructor trained us to take current measurements rather then use a current probe .Why he felt it wasn’t necessary to use in SMP’s I don’t know. This just makes sense when you calculate the efficiency you use the average value of the input current.
