https://journals.tubitak.gov.tr/elektrik/issues/elk-02-10-3/elk-10-3-5-0203-2.pdf[/url] ]Converter 1: A standard forward converter having a reset winding with Schottky output rectifiers. Main switch is switched lossy (Non-ZVS).
Converter 2: An active clamp forward converter with Schottky output rectifiers. Main switch is switched lossy (Non-ZVS).
Converter 3: An active clamp forward converter with Schottky output rectifiers and a magnetic amplifier that enables soft switching of the main switch (ZVS).
Converter 4: A standard forward converter having a reset winding with control driven synchronous rectifiers. Main switch is switched lossy (Non-ZVS).
Converter 5: An active clamp forward converter with synchronous rectiers and a magnetic amplifier. All switches are soft switched (ZVS).
