viperpaki007
Full Member level 5
I am having a confusion in understanding increase of Vth voltage by increasing Vsb voltage. I am quoting from Behzad Razavi book [1].
"As Vb becomes more negative, more holes are connected to the substrate connection, leaving a large negative charge behind, i.e., as depicted in Fig. 2.22, the depletion region becomes wider. now recall from Eq. (2.1) that the threshold voltage is a function of total charge in depletion region because the gate charge must mirror Qd before an inversion layer is formed.Thus, as Vb drops and Qd increases, Vth also increases. This is called body effect".
My question is, if there are more electrons in the depletion region then less voltage at gate should be required in order to make the current flow between drain and source (i.e to create an inversion layer). This means Vth should decrease not increase. Can somebody explain this.
regards
regards
