* Carbon Nanotube Field Effect Transistors
* HSPICE Model
* Version 2.2.1
* Copyright The Board Trustees of the Leland Stanford Junior University 2009
* Albert Lin, Gordon Wan, Jie Deng, Prof. H-S Philip Wong
* All Rights Reserved.
* 09/09/2008 Last Modified by Albert Lin.
* Carbon Nanotube Field Effect Transistors Verilog-A implementation
* based on
* "A Circuit-Compatible SPICE model for Enhancement Mode Carbon
* Nanotube Field Effect Transistors" by Jie Deng and H-S Philip Wong
* Patent Pending.
* File name: cnfet_sample.sp
* LICENSE AGREEMENT
* Stanford Leland Junior University and the authors ("Stanford")
* provide these model files to you subject to the License Agreement,
* which may be updated by us from time to time without notice to you.
* The most-up-to-date License Agreement can be found at
* **broken link removed**
*Sample HSPICE Deck
.TITLE 'IDS vs VGS for CNFET'
*For optimal accuracy, convergence, and runtime
.options POST
.options AUTOSTOP
.options INGOLD=2 DCON=1
.options GSHUNT=1e-12 RMIN=1e-15
.options ABSTOL=1e-5 ABSVDC=1e-4
.options RELTOL=1e-2 RELVDC=1e-2
.options NUMDGT=4 PIVOT=13
.param TEMP=27
*Include relevant model files
.lib 'CNFET.lib' CNFET
*Beginning of circuit and device definitions
*Supplies and voltage params:
.param Supply=0.9
.param Vg='Supply'
.param Vd='Supply'
*Some CNFET parameters:
.param Ccsd=0 CoupleRatio=0
.param m_cnt=1 Efo=0.6
.param Wg=0 Cb=40e-12
.param Lg=32e-9 Lgef=100e-9
.param Vfn=0 Vfp=0
.param m=19 n=0
.param Hox=4e-9 Kox=16
* Define power supply
Vdd Drain Gnd Vd
Vss Source Gnd 0
Vgg Gate Gnd Vg
Vsub Sub Gnd 0
* Main Circuits
* nFET
XCNT Drain Gate Source Sub NCNFET Lch=Lg Lgeff='Lgef' Lss=32e-9 Ldd=32e-9
+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbn='Vfn' Dout=0 Sout=0 Pitch=20e-9 n1=m n2=n tubes=3
* pFET
*XCNT Drain Gate Source Sub PCNFET Lch=Lg Lgeff='Lgef' Lss=32e-9 Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbp='Vfp' Dout=0 Sout=0 Pitch=20e-9 n1=m n2=n tubes=3
* nFET uniform-tubes model
*XCNT Drain Gate Source Sub NCNFET_uniform Lch=Lg Lgeff='Lgef' Lss=32e-9 Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbn='Vfn' Dout=0 Sout=0 Pitch=20e-9 n1=m n2=n CNTPos=1 tubes=3
* pFET uniform-tubes model
*XCNT Drain Gate Source Sub PCNFET_uniform Lch=Lg Lgeff='Lgef' Lss=32e-9 Ldd=32e-9
*+ Kgate='Kox' Tox='Hox' Csub='Cb' Vfbp='Vfp' Dout=0 Sout=0 Pitch=20e-9 n1=m n2=n CNTPOS=0 tubes=3
* Measurements
* test nFETs, Ids vs. Vgs
.DC Vgg START=0 STOP='Supply' STEP='0.3*Supply'
+ SWEEP Vdd START=0 STOP='Supply' STEP='0.3*Supply'
.temp 100 150 200
* test pFETs, Ids vs. Vgs
*.DC Vgg START=0 STOP='-Supply' STEP='-0.01*Supply'
*+ SWEEP Vdd START=0 STOP='-Supply' STEP='-0.1*Supply'
.print I(Vdd)
.end
