I have interfaced EEPROM (24C02A) with AT89C2051 ...
but data is not written to EEPROM ,can u anyone tell me where is the problem.
take a look on attached code
#define SDA P3_4
#define SCL P3_5
void I2C_Delay()
unsigned char i;
for(i=0;i<I2C_DELAY;i++)
/* Used for Clok Initiation */
void I2C_Clock()
I2C_Delay();
SCL = 1; /* Start clock */
I2C_Delay();
SCL = 0; /* Clear SCL */
/* Used for i2c communication start */
void I2C_Start()
if(SCL)
SDA = 1; /* Set SDA */
SCL = 1; /* Set SCL */
I2C_Delay();
SDA = 0; /* Clear SDA */
I2C_Delay();
/* Used for stop communication */
void I2C_Stop()
if(SCL)
I2C_Delay();
I2C_Delay();
/* Used for check the bus is idle or not */
void I2C_Idle()
if(SDA)
SDA=0;
if(SCL)
SCL=0;
// Used for Acknowledgement
void I2C_Ack()
// SDA = 0; /* Clear SDA */
//I2C_Delay();
I2C_Clock(); /* Call for send data to i2c bus */
// SDA = 1; /* Set SDA */
/* Used for write data through I2C data pin */
void I2C_Write(unsigned char dat)
// bit data_bit;
unsigned char i;
for(i=0;i<8;i++) // For loop 8 time(send data 1 byte)
if((dat& 0x80)==0x80) // Filter MSB to keep data bit
SDA=1; // put the value on SDA pin
else
SDA=0;
dat = (dat <<1);
SDA=0;
/* Used for read data through I2C data pin */
unsigned char I2C_Read()
bit rd_bit;
unsigned char i,dat;
dat = 0x00;
for(i=0;i<8;i++) /* For loop read data 1 byte */
I2C_Delay();
I2C_Delay();
rd_bit = SDA; /* Keep for check acknowledge */
dat = dat <<1;
dat = dat | rd_bit; /* Keep bit data in dat */
SDA=0;
return dat;
void EEPROM_Write(unsigned char EAddress,unsigned char Edata)
// I2C_Delay(); // Generate i2c delay condition
// I2C_Idle(); // Generate i2c idle condition
I2C_Start(); // Generation of start condition
I2C_Write(0xA0); // 0xA0 is the EEPROM ADDRESS for Write Operation
I2C_Ack();
// I2C_Idle();
I2C_Delay();
// I2C_Write(EAddress>>8); // send higher address
// I2C_Delay();
// I2C_Write(EAddress); // send lower byte
I2C_Ack(); // Get Acknowledgement
// I2C_Delay();
// I2C_Write(Edata>>8); // send higher data
// I2C_Ack(); // Get Acknowledgement
// I2C_Delay();
I2C_Write(Edata); // send higher data
I2C_Ack();
// I2C_Delay();
I2C_Stop(); // Generate a stop condition
Delay(2); // used for internal write cycle..
/* This function is used for fetching data from EEPROM */
unsigned char EEPROM_Read(unsigned char EAddress)
unsigned char i;
unsigned int Read_Data; // used to store the read data
// I2C_Idle(); // Generate a i2c idle condtion
I2C_Start(); // Generate a i2c start condition
I2C_Delay(); // Generate a delay condtion
// I2C_Delay();
I2C_Write(EAddress); // send the address where data will be stored
// I2C_Delay();
I2C_Start(); // Restart the I2C for read operation
I2C_Write(0xA1); // 0xA1 is used for EEPROM Read opeartion
i=I2C_Read();
// I2C_Delay();
// j=I2C_Read();
I2C_Delay();
I2C_Stop(); // Generate stop condition to stop i2c
I2C_Ack(); // Get the acknowledgement
// Read_Data=100*i+j;
Read_Data=100*i;
return Read_Data;
please find the problem
arup26pradhan@gmail.com
