MachaniGoutham
Newbie level 5
- Joined
- Nov 10, 2011
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,458
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 #include <proc/p32mx450f128h.h> #include "uart_fun.h" // PIC32MX450F128H Configuration Bit Settings // Configuration Bit settings // SYSCLK = 48 MHz (8MHz Crystal / FPLLIDIV * FPLLMUL / FPLLODIV) // PBCLK = 48 MHz (SYSCLK / FPBDIV) // Primary Osc w/PLL (XT+,HS+,EC+PLL) // WDT OFF // Other options are don't care #pragma config FPLLMUL = MUL_16, FPLLIDIV = DIV_2, FPLLODIV = DIV_4, FWDTEN = OFF #pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_1, JTAGEN = OFF, FSOSCEN = OFF #pragma config ICESEL = ICS_PGx1 #define SYS_FREQ (16000000L) #define EEPROM_ID 0xA0 #define BRG_VAL 0x04E #define ON 1 #define OFF 0 #define STARTI2C1 I2C1CONbits.SEN #define STOPI2C1 I2C1CONbits.PEN #define RESTARTI2C1 I2C1CONbits.RSEN #define ACKI2C1 I2C1CONbits.ACKEN #define TRANSMITSTATUS_BF I2C1STATbits.TBF #define RECIEVESTATUS_BF I2C1STATbits.RBF #define R_WSTATUS I2C1STATbits.R_W #define I2CIDLEBUS STARTI2C1|STOPI2C1|ACKI2C1|TRANSMITSTATUS_BF|RECIEVESTATUS_BF //function initiates I2C1 module to baud rate BRG void I2C1_Init() { // I2CBRG = 78 for 8Mhz OSCI with PPL with 100kHz I2C clock I2C1BRG = BRG_VAL; I2C1CONbits.I2CEN = OFF; // Disable I2C Mode I2C1CONbits.DISSLW = ON; // Disable slew rate control IFS1=0x00; // Clear Interrupt I2C1CONbits.I2CEN=ON; // Enable I2C Mode I2C1CONbits.SIDL=OFF; // Module Continues in Idle mode I2C1CONbits.A10M=OFF; // 0=I2CxADD is a 7-bit slave address I2C1CONbits.ACKDT = ON; // setting Ack by Master operationI ACKI2C1 = OFF; I2C1RCV=0x00; // read buffer to clear buffer full Uart1SendString("I2C Initalized");Uart1Send(0x0D); Uart1Send(0x0A); } //function iniates a start condition on bus void I2C1_Start(void) { STARTI2C1= ON; //Initiate Start condition while(STARTI2C1); //wait for automatic clear before proceding Uart1SendString("I2C Started");Uart1Send(0x0D); Uart1Send(0x0A); } //stop the I2C bus to Idle void I2C1_Stop(void) { //initiate stop bit STOPI2C1= ON; //wait for hardware clear of stop bit while (STOPI2C1); Uart1SendString("I2C Stoped");Uart1Send(0x0D); Uart1Send(0x0A); } //restart i2c bus void I2C1_Restart(void) { RESTARTI2C1=ON; //Initiate restart condition //the hardware will automatically clear restart bit //wait for automatic clear before proceding while (RESTARTI2C1); Uart1SendString("I2C Restarted");Uart1Send(0x0D); Uart1Send(0x0A); } //I2C Idle state void IdleI2C() { if(I2CIDLEBUS); Uart1SendString("I2C @ IDLE STATE");Uart1Send(0x0D); Uart1Send(0x0A); } // write I2C void WriteI2C1(unsigned char data) { unsigned char x; IdleI2C(); I2C1TRN = data; // load the outgoing data byte x=I2C1TRN; while (I2C1STATbits.TRSTAT); // wait untill TBF-1 transmit is in progress...0-transmit Completed Uart1SendString("I2C Write completed");Uart1Send(x); Uart1Send(0x0D); Uart1Send(0x0A); } //function reads data I2C, unsigned char ReadI2C1(void) //does not reset bus!!! { unsigned char data; I2C1CONbits.RCEN = 1; //set I2C module to receive while(I2C1CONbits.RCEN){}; I2C1STATbits.I2COV=0; // update to I2CRCV register clearing manually while(I2C1STATbits.RBF){ // wait to clear recive buffer data = I2C1RCV; //get data from I2CRCV register } Uart1SendString("Read Completed"); Uart1Send(0x0D); Uart1Send(0x0A); return data; //return data } // ACK I2C1 void Ackl2C (void) { I2C1CONbits.ACKDT = OFF; // setting Ack by Master operationI ACKI2C1 = ON; //Ack enabled while(ACKI2C1); // wait Nack cleared } // NACK I2C1 void Nackl2C (void) { I2C1CONbits.ACKDT = ON; // setting Ack by Master operationI ACKI2C1 = ON; //Ack enabled } unsigned char EEByteWrite(unsigned char c, unsigned char address, unsigned char data) { IdleI2C(); // ensure I2C bus is idle I2C1_Start( ); // initiate START condition if (I2C1STATbits.BCL) // test for bus collision return (-1); // return with Bus Collision error WriteI2C1(c); // write byte - R/W bit should be 0 IdleI2C(); // ensure module is idle if (I2C1STATbits.ACKSTAT) // test for NACK condition received return (-2); WriteI2C1(address); // write word address for EEPROM IdleI2C(); // ensure module is idle if (I2C1STATbits.ACKSTAT) // test for NACK condition received return (-2); WriteI2C1(data); // data byte for EEPROM IdleI2C(); // ensure module is idle I2C1_Stop(); // send STOP condition if (I2C1STATbits.BCL) // test for bus collision return (-1); // return with Bus Collision error Uart1SendString("EEprom write Sucess"); return (0); // return with no error } unsigned char EERandomRead( unsigned char c, unsigned char address) { unsigned char edata; IdleI2C(); // make sure I2C module is idle I2C1_Start(); // assert a START condition WriteI2C1(c); // write byte - R/W bit should be 0 IdleI2C(); // ensure module is idle if (I2C1STATbits.ACKSTAT) // test for NACK condition received return (-2); WriteI2C1(address); // write word address for EEPROM IdleI2C(); // ensure module is idle if (I2C1STATbits.ACKSTAT) // test for NACK condition received return (-2); I2C1_Restart(); // assert I2C bus restart condition if (I2C1STATbits.BCL) // test for bus collision return (-1); // return with Bus Collision error WriteI2C1(0xA1); // write 1 byte - R/W bit should be 1 IdleI2C(); // ensure module is idle if (I2C1STATbits.ACKSTAT) // test for NACK condition received return (-2); edata=ReadI2C1(); Nackl2C (); while(ACKI2C1); I2C1_Stop(); // send STOP condition if (I2C1STATbits.BCL) // test for bus collision return (-1); // return with Bus Collision error Uart1SendString("EEprom read Sucess"); Uart1Send(0x0D); Uart1Send(0x0A); return edata; // return with data } void DelayuSec(unsigned int n) //loop nops for delay { unsigned int j; while(n>0) { for(j=0;j < 10; j++); n--; } } void main() { unsigned char Eodata[14],i,address; UART1PPSInit(); UART1Initialise(); Uart1SendString("uartworking");Uart1Send(0x0D); Uart1Send(0x0A); I2C1_Init(); EEByteWrite(0xA0,0x00,'G'); EEByteWrite(0xA0,0x01,'o'); EEByteWrite(0xA0,0x02,'u'); EEByteWrite(0xA0,0x03,'t'); EEByteWrite(0xA0,0x04,'h'); EEByteWrite(0xA0,0x05,'a'); EEByteWrite(0xA0,0x06,'m'); EEByteWrite(0xA0,0x07,'R'); EEByteWrite(0xA0,0x08,'o'); EEByteWrite(0xA0,0x09,'c'); EEByteWrite(0xA0,0x0A,'k'); EEByteWrite(0xA0,0x0B,'z'); EEByteWrite(0xA0,0x0C,'O'); EEByteWrite(0xA0,0x0D,'n'); Eodata[0]=EERandomRead(0xA0,address); Uart1Send(Eodata[0]); address=0x00; for(i=0;i<14;i++){ Eodata[i]=EERandomRead(0xA0,address); address++; } // Uart1Send(0x0D); Uart1Send(0x0A); // for(i=0;i<14;i++){ // Uart1Send(Eodata[i]); // } // Uart1Send(x); Uart1SendString(Eodata); }
