lead selector ecg
This is my first post and also this will be basic because my digital circuits skills have become useless in the years gone by. For reference: RA is right arm, LA is left arm, and RL is right leg.
I have built a simple 3 lead ECG circuit using an AD620 IC. The next step is to add a lead selector switch which closes 1 input and opens the other 2 (either RA, LA, or RL) and also closes all 3 with another option. To make it less complicated:
Position 1: RA closed, LA open, RL open
Position 2: LA closed, RA open, RL open
Position 3: RL closed, RA open, LA open
Position 4: All leads closed
From what I understand, this can be made by using a rotary wafer switch or dip switches but my concept is this:
I wish to create a digital circuit that controls which leads are open and closed (using a modular pushbutton switch) and the closed lead is displayed on two 7 segment display in numeric 01, 02, 03, 04 as RA, LA, RL, and All respectively. What would be even better is if the display showed alphabetic rA, LA, rL, and AL instead (lower case R because it looks like a capital A in a 7 segment display).
This circuit will be at the input of the AD620 sending the closed lead to the input and the open leads to ground.
I need a push out the door as to what components can be used to create the contraption I have described, if it is even possible. Any input is appreciated, even the complicated ones.
