Easy way to make text files from Spectra files
bijug007
Junior Member level 3
hi,
any interactive method to create do files other than text editor?
thanks
Nyar
specctra do files
When you work in specctra, everything you do is recorded in a *.did file. You could simply delete the unnecessary parts with a text editor and rename it as a *.do file.
centiago
Full Member level 3
Lions Den
specctra make do
Gone are the days when we had to spend hell lot of time creating do files.
Now Constraint Manager (CM) does all, you can access it from any platform. CM takes care of all, try it. I am sure you will find it user friendly.
Good Luck
Alexj
Junior Member level 1
specctra do file
There is a MAKEDO software you can make do file and check the file , pls search in internet.
