Eagle Pro....Make assembly diagram...bottom layer..viewed from bottom...how?
T
treez
Hello,
I have done a 4 layer PCB with components on top and bottom layers.
I need an assembly diagram for top and bottom...........but how do i get the bottom layer viewable from the bottom (at the moment the silkscreen designators are the wrong way round, because its viewing the bottom from the top, so to speak.
The assembly diagram will just have the bnames, bplace , dimension, and bdocu ('bdocu' has been used as a component "courtyard" marker outer, so it is good for kind of showing where a componnet is.)
Select "MIRROR" in the print dialog.
Keith
Reactions: treez
    T
