e-con Systems™ Launches Multi-camera Solution for NVIDIA Jetson AGX Orin Based on Sony STARVIS IMX485
shaun26
Newbie
Newbie level 3
e-con Systems, a leading embedded OEM camera company and an NVIDIA Elite Partner, today launched the e-CAM82_CUOAGX – a 4K ultra-low-light camera powered by the NVIDIA® Jetson AGX Orin™ system-on-a-module and based on the Sony STARVIS IMX485 sensor.
This large sensor camera (1/1.2”) can be readily integrated with NVIDIA Jetson AGX Orin and is designed to address the rising processing needs of AI-based embedded vision applications such as autonomous mobile robots and agricultural vehicles. This large sensor size will also enable
e-CAM82_CUOAGX to capture high-resolution images with more detail and clarity.
In addition, this low-light camera houses the Sony STARVIS IMX485 sensor with a large pixel size of 2.9µm (H) x 2.9µm (V), which is double the size of most 4K sensors available in the market today. This, in turn, will ensure high sensitivity even in absolute darkness.
