bobsun
Full Member level 2
Hello,
I would like to ask a question on GND plane.
In order to provide double side reference plane for stripline signals I am using more than one ground planes (see doublegnd.png). The question is: If I am using more than one (two here) GND planes, do I have to make them exactly the same? Most of the areas on the two GND planes will be connected to GND signal, but there are also planes cuts that are connected to either GND_DAC, GND_DENC or other grounds.
Therefore, if I am having ground plane 1 and ground plane 2, do I have to make the cuts on them the same? In more detail, if GND_DAC is cut on ground plane 1, do I have to cut it again in ground 2?
Are there any pros and cons for duplicate planes cuts or not?
Thanks,
Bob
Thanks,
Bob
