dtmf decoder circuit trobleshooting
You check the signal at each of the circuit nodes and determine which is not correct.
Without a circuit diagram I can't comment further.
this circuit i have used
Some problems:
1. you do not need C1 and C2.
2. Check the crystal is 3.579MHz
3. R4 & R5 are shorted out
4. any reason why R4 and R5 are in parallel?
Please tell us the component values you are using.
Brian.
