dspic33f family reference manual
Hi, I have some problems with my project:
I use one dsPIC33f , mean that i have to work with 3.3 V supply. Now i want to interface through RS232 and work with LCD 4x16, other ICs : OAMP741,MAX232,...
1. for OAMP741, can i use +/- 5V instead +/- 9V ?
2. Can i use 3.3V to supply LCD, OAM741,... ? (if so, i only have to supply 3.3V & +/-9 V and dont need 5V ?)
3. Should i change MAX232 with MAX3232 instead (cause Max3232 works with 3.3V)
For RS232 connection, the capacitors use for MAX232/MAX3232 should be 1uF or 10uF,... is the best?
And in the datasheet of max3232/max232 , they use one cap 0.1up as bypass function. That mean they use total 5 caps. In some sources, they use only 4 caps??
4. I use dsPIC33FJ256MC710 (a bit troublesome
, cause i'm very new at it). Which is the best OSC for this dsPIC (20Mhz / 40Mhz / 80Mhz .. . )?. I read the datasheet of dsPic family and cant really understand the use of PLL to multiple OSC... It says that at Fosc=80Mhz then the calculating rate could be maximum = 40MIPs .
5. then the last purpose is to display the temperature of a heat-exchange and send data to a PC. How can i reduce the disturbances to the AD convert? One of my friend used Caps 104pF & Registors to filter the analog signal at input pin. is that ok ?
