Prabakaran
Full Member level 3
- Joined
- Jan 22, 2007
- Messages
- 167
- Helped
- 9
- Reputation
- 18
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Chennai(India)
- Activity points
- 2,273
u2txreg
Hello,
I m using dsPIC30F6010A controller in which i can send the data to serial port but when i m configuring as a interrupt to receive a single character from serial port . I am not able to receive the data from serial port .Please find the code below and say any corrections to be done.
This is my Code.
#include <p30f6010A.h>
#define BUTTON1 !PORTGbits.RG6 //S4 on PCB
#define BUTTON2 !PORTGbits.RG7 //S5 on PCB
#define BUTTON3 !PORTGbits.RG8 //S6 on PCB
#define BUTTON4 !PORTGbits.RG9 //S7 on PCB
#define RS485_TX PORTFbits.RF5// Tx pin
#define RS485_RX PORTFbits.RF4 // rx pin
// This the RS485_TXENA (active high line)
#define RS485_TXENA LATGbits.LATG1
// This the RS485_RXENA (active LOW line)
#define RS485_RXENA !LATGbits.LATG0
void delay1( long t);
void Init(void);
void Delay(unsigned long count);
void serial_send(char *str1);
void __attribute__((__interrupt__)) _T1Interrupt(void);
long timer1cnt = 0;
char timer_bit;
unsigned int value=65;
* Configuration Bits
//_FOSC(CSW_FSCM_OFF & FRC_PLL8); /* Fast RC with PLLx8 = 16MIP Clock Mon/Switch OFF */
//_FOSC(CSW_FSCM_OFF & XT_PLL8); /* 8MHz Crystal with PLLx8 = 16 MIP */
//_FWDT(WDT_OFF); /* Watch dog Timer OFF */
//_FBORPOR(PBOR_OFF & MCLR_EN); /* Brown Out OFF, MCLR Enabled */
//_FGS(CODE_PROT_OFF); /* Code Protect OFF */
int main(void)
Init();
while(1)
if(U2STAbits.URXDA)
U2TXREG = 65;
ClrWdt();
return(0);
int j;
long i;
for(j=0;j<10;j++)
for(i=0;i<t;i++)
ClrWdt();
unsigned int j;
for(j=0;j<count;j++)
ClrWdt();
while(*str1 !=0)
while(U2STAbits.UTXBF==1); /* Wait until TX buf read for new data */
U2TXREG=*str1;
str1++;
//delay1(10000);
void Init()
//OSCCON=0x3300; /* Select Primary Oscillator */
/* Set up I/O Port */
ADPCFG=0xFFFF; /* Analog ports as Digital I/O */
U2BRG=96; /* 9600Baud for 16MIP (See FRM Tables) */
U2MODE=0x8000; /* Enable, 8data, no parity, 1 stop */
U2STA =0x8400; /* Enable TX */
TRISB=0x0000; /* Port B output Data as well as serial port */
LATB=0x0000; /* Initial Value of 0 */
// Configuring the switch as Input
TRISG = 0xFFFF;
LATG = 0x0000;
TRISF = 0xFFFF;
LATF = 0x0000;
///IFS1bits.U2RXIF = 1; //Clear UART Rx interrupt flg
IEC1bits.U2RXIE = 1; //Enable UART Rx receive interrupt
IPC6bits.U2RXIP = 3;
TRISA = 0x39FF;
PORTA = 0x8000;
delay1(100000);
PORTA = 0x4000;
delay1(100000); //4805
PORTA = 0x0400;
delay1(100000);
PORTA = 0x0200;
delay1(100000); //2400 - 56 2500 - 28
PORTA = 0;
U2TXREG = 50;
IFS0bits.U1TXIF = 0;
void __attribute__((__interrupt__))_U2RXInterrupt(void)
while(U2STAbits.URXDA) //If Rx FIFO buffer has data
while(U2STAbits.UTXBF); //Wait if Transmit buffer is full
U2TXREG = U2RXREG; //Echo received char
IFS1bits.U2RXIF = 0; //Clr UART_Rx interrupt flag
void timer1_init(void)
T1CON = 0x8040;
// IFS0bits.T1IF = 0;
IEC0bits.T1IE = 1;
TMR1 = 0;
PR1 = 2000;
Thanks
M.Prabakaran
Hello,
This is my Code.
void Init(void);
long timer1cnt = 0;
char timer_bit;
int main(void)
Init();
while(1)
if(U2STAbits.URXDA)
U2TXREG = 65;
ClrWdt();
return(0);
int j;
long i;
for(j=0;j<10;j++)
for(i=0;i<t;i++)
ClrWdt();
unsigned int j;
ClrWdt();
while(*str1 !=0)
U2TXREG=*str1;
str1++;
//delay1(10000);
void Init()
TRISG = 0xFFFF;
LATG = 0x0000;
TRISF = 0xFFFF;
LATF = 0x0000;
TRISA = 0x39FF;
PORTA = 0x8000;
delay1(100000);
PORTA = 0x4000;
PORTA = 0x0400;
delay1(100000);
PORTA = 0x0200;
PORTA = 0;
U2TXREG = 50;
T1CON = 0x8040;
IEC0bits.T1IE = 1;
TMR1 = 0;
PR1 = 2000;
Thanks
M.Prabakaran
