P.Copper
Member level 5
- Joined
- Mar 18, 2013
- Messages
- 82
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,807
Hi all
I want to test the ADC of dsPIC30f4013, what i really want to see at the output is to control an LED brightness by just using a variable resistor. I connected an LED to pin 3 of PORTD and my analog input is all PORTB pins. for analog input I'm supplying a 47K potentiometer with 2 volts(DC). the problem i'm having is i run the code but nothing happens...... here's the code
#include "p30f4013.h"
#include <libpic30.h>
//*******SYSTEM CONFIGURATION BITS*******
_FOSC(CSW_FSCM_OFF & FRC); //Internal fast RC oecillator
_FWDT(WDT_OFF); //Disable the watcdog timer
_FBORPOR(MCLR_EN & PWRT_OFF); //Enable the master clear pin
_FGS(CODE_PROT_OFF); // Disable code protection
void configure_pins();
unsigned int read_analog_channel(int n);
int main()
long int n;
// Set up which pins are which
configure_pins();
while(1)
// Read the analog channel. The result is an
// integer between 0 and 1023 inclusive.
n = read_analog_channel(0);
// LED on
_LATD0 = 1;
__delay32(30*n); // m us
// LED off
_LATD0 = 0;
__delay32(30*(1023 - n)); // (1023-m) us
return 0;
// Configure digital I/O
LATD = 0;
TRISD = 0b11111110;
// Configure analog inputs
TRISB = 0x01FF; // Port B all inputs
ADPCFG = 0xFF00; // Lowest 8 PORTB pins are analog inputs
ADCON1 = 0; // Manually clear SAMP to end sampling, start conversion
ADCON2 = 0; // Voltage reference from AVDD and AVSS
ADCON3 = 0x0005; // Manual Sample, ADCS=5 -> Tad = 3*Tcy = 0.1us
ADCON1bits.ADON = 1; // Turn ADC ON
// This function reads a single sample from the specified
// analog input. It should take less than 2.5us if the chip
// is running at about 30 MIPS.
unsigned int read_analog_channel(int channel)
ADCHS = channel; // Select the requested channel
ADCON1bits.SAMP = 1; // start sampling
__delay32(30); // 1us delay @ 30 MIPS
ADCON1bits.SAMP = 0; // start Converting
while (!ADCON1bits.DONE); // Should take 12 * Tad = 1.2us
return ADCBUF0;
