I am new to processor design world, I have never worked on DSP processors but now I need to work on DSP processors. Please suggest me some ways about how to start with.
You can start with Digital Signal Processing and Applications with the TMS320C6713 and TMS320C6416 DSK (Topics in Digital Signal Processing) or Real-Time Digital Signal Processing: Based on the TMS320C6000
Thanks Alpuslu. Actually, I did work with 8051 only once long before but now didn't remember any thing. Do you think, handeling this book will be easier for me ?
Programming a DSP processor is like programming any processor. You need to know its instructions. Moreover, new processors have c compilers that can be programmed in C just any like embedded processor.
It depends on your target DSP processor.
I used a TI dual core (ARM + DSP) called Davinci. I was lucky to program on the DSP directly.
DSP processors of TI can be programmed used a tool called Code Composer Studio.
Check it.
Check it.
(ARM + DSP) means DSP and Microcontroller unit in one package ?
Is Code Composer Studio a simulator ?
Added after 3 minutes:
I haven't selected any processor yet, actually I need to select a processor for my application. I would like to build a Real Time FFT Display Unit that will compute 2048- Point FFT. Without having good knowlwdge about DSP, I can't select the processor...
You can start with c5505 from texas instruments.It has 10 bit integrated analog to digital converter.You can buy TMDX5505EZDSP board to delevop your applications.This packet includes code composer studio and very cheap.For more details try to google it.
One thing I would like to ask, how can we be sure that any processor can perform 1024 or 2048 points FFT ? Lets suppose, I have a 32 bit procossor, does it mean it can perfoem 2^32 bit point FFT ? Or how can we get this information ?
