Dsp and ethernet controller
J
Jerry_chan
Newbie level 1
dsp ethernet
I want to use a DSP(TMS320C54x) to interface with an ethernet controller.Who can tell me which one is appropriate for the DSP?
Thank you!
I think you need some glue logic -EPLD- to translate the DSP R/W cycles to ISA cycles -PCI is much more complicated-.
If you use some ISA Ethernet controller, like Realtek RTL8029, you have it.
I don't know if this helps you.
Regards.
You should use PLD or CPLD for a DSP to interface with an ethernet controller (DSP- PLD or CPLD-ethernet controller)
I have found two non-PCI controllers, Cirrus CS8900A and Realtek RTL8019AS.
If you want 100Mbit, you are stuck with PCI or USB controllers
Does anybody know about any others non-PCI controllers ?
there are some 10/100MBit controllers from LSILOGIC and SMC:
h**p://www.lsilogic.com/products/networking/controllers.html
h**p://www.smsc.com ....
